Best Radiator For boost?
wingnutt
@FL410
michael
350R Procharged w/P1X
Mishi is the only thing that fixed mine too…that stage 2 intercooler is just a big airflow blocker 😂
Bob Lob Law
Jeff
'22 GT 401A ESS A10
Is this Mishimoto radiator a direct drop in or modifications necessary?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Stock PP radiator here. Big air to water IC up front and working AC. Also have Ford Performance water pump and 170 stat. Street duty and drag racing is no issue, in any temp.
wingnutt
@FL410
michael
yea, but you live in Ohio 😛
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
High and low coolant temps of datalogs, stock rad/therm, then after changing to a 170 thermostat, and then after adding the Mishimoto radiator
What was the outside air temperature during these logs ?
Unas2k5
Detroit
Samer
I have a procharger. Would the procharger be in the way of a larger radiator ? That’s my issue. Anyone running a larger radiator with a procharger ?
Unas2k5
Detroit
Samer
Does anyone know if there is a way to have my fans turn on without contacting Lund for a revision? I have an RTD device.
robvas
MI
2011 GT
All different. Each line is a log so you can see the general trend.
Changing the thermostat removes the floor of 190 degrees and then after the radiator the car basically never gets to 195 degrees
wingnutt
@FL410
michael
yep…their stage 2 cooler was enough of an airflow restrictor to throw me into limp mode on a 104* day, and a quick highway pull 😏
wingnutt
@FL410
michael
Unas2k5
Detroit
Samer
What cooling upgrades helped with the issue?
G.T.
Asia
Glenn
2016 Ford Mustang GT Premium
Thanks for posting this.
Fan algorithim same throughout, I assume?
