Battery Issues / Voltage Regulator?
JMunks
New Jersey
2016 Mustang GT Premium
Went to start the car the other day and it clicked, and no dice.
Figured it was the battery, went to Autozone, replaced it, and it started up beautifully.
However, the guy went to go and test the new battery and his device came back “Voltage Regulator Failed”
We also saw the voltage dropping from 13.5 to 13.2, and when I was driving it home,
at stop, it would get down to around 12.5.
I’ve scoured the forums and see some
mention of smart battery systems, but I’m not sure if that applies to my case here as to what’s going on.
Also don’t really wanna bring it to the shop and pay $200 just to find out it’s normal lol.
Farkel
Cartoon City, Nirvana
Marc
'20 GT Premium PP1, 2012 Jeep JK, 2022 Harley 48
It's possible that the "voltage regulator failed" may be due to the tester not playing well with the car's battery management system, but I can't say for sure.
The voltage numbers you're seeing are normal for a fully charged battery. Remember, when the engine is running that number shows the alternator output, not the battery voltage.
After replacing the battery, you should reset the BMS to let the charging system know the battery is new - https://www.mustang6g.com/forums/threads/bms-reset-no-tools-required.151602/
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
The PCM regulates alternator output only to what's necessary when the battery is a high enough state of charge (I think above 80%), so that's why you're seeing the low voltage with a fresh battery. Helps with efficiency.
JMunks
New Jersey
Gotcha. Would that explain then the “failed” outcome on the autozone tester for the voltage regulator?
WItoTX
Houston
Kyle
'17 GT350
I would be speculating how an AutoZone tester works. I'd say it's normal based on what you reported. Reset the BMS, if you haven't already, and I suspect it will be fine.
