oguruma
My job necessitates that my car be something of a mobile office, so I want to mount my laptop in the car with a Ram Mounts/Gamber Johnson mount.
I'd like to add a small LiFePO4 auxiliary battery so the laptop doesn't have to pull from the starting battery, and I'd like to add some kind of timer that can sense whether or not the car is running, and if the car the stops running for 30(?) minutes to disconnect the laptop from the aux battery.
The idea being that the laptop will continue to charge for a while after the car stops running. I may add a small mobile LTE router and/or dash cam that runs off the same aux battery.
Basically it would be something like Starting Battery -> 12V Charge Controller -> Auxiliary Battery -> ??? -> Laptop/Electronics.
I know there are Low Voltage Timers that exist in the market but those don't work with LiFePO4 batteries, from what I gather, since it's not adviseable to run a LiFePO4 battery directly in parallel with a Lead Acid/Starting battery.
