B&O 10" sub replacement guide
m3incorp
Georgia/Colorado
James
Yep remember we exchange quite a few messages when you were trying to figure where to run the turn on cable to get rid of the thump. The JL Audio is a great sub and would work for those that aren't like us and need a real enclosure. :)
Cathul
Germany
Peter
Ford Mach-E
that’s bad ass. Is that a tw series? Has to be
oh you’re saying you put another box in there? I did the same dual tw1 box
Most probably a W1, not a tw. A tw has a different cone.
Gregs24
Gregs24
Wiltshire UK & Charente FR
Greg
Mustang V8 GT, Ford Kuga PHEV
I used this JL Audio, but since I like to feel the bass, no 10" in that small enclosure is going to work for me. I left it in there, even though I unhooked it and installed a real 12" subwoofer enclosure. BTW I didn't break my trim ring when I removed it.
That speaker is also 267mm outer diameter and so also just fits without having to remove the ridges. Single voice coil though.
Gregs24
Gregs24
Greg
This is from the 5G forum and updated
Just to help people out, here are a few measurements. B&O enclosure: Remember 267mm will fit inside the ridges and about 277 inside the main recess. Maximum depth is 146mm (or 160mm with mild modification) Nothing in excess of 160mm deep will fit without a spacer. Volume of enclosure is 17.5 litres (0.64 cu ft)
Inner hole size, outer size, depth, sensitivity, dual or single coil (all 4 ohm unless stated)
Pioneer TS-A250D4 (TS-A100D4 in the US) - 230 , 267 , 77, 133, dual (ÂŁ70)
Dayton RSS265HO-4 - 230, 267, 87, 137, single ($135 NOT UK)
Dayton RSS265HO-44 - 235, 266, 90, 137, dual (will not fit without modification)($155 NOT UK)
Focal RSB-250 - 233, 271, 88, 117, dual (will not fit without modification) (ÂŁ90)
Rockford Fosgate R2SD4 - 232, 275, 82, 87, dual (will not fit without modification)(ÂŁ75)
JL10W0V3-4 - 230, 267, 84, 124, single (ÂŁ100)
Focal 25A4 - 230, 260, 85, 126, single (ÂŁ80)
Rockford Fosgate R2D4 - 232, 275, 89, 110, single (will not fit without modification) (ÂŁ70)
Rockford Fosgate P2D4-10 - 232, 280(exc trim ring), 84, 150, dual (will not fit without modification) (ÂŁ120)
JL10W1V3-4 - 230, 267, 84, 117, single (ÂŁ200)
Redline SW10-D4 - 228, 260, 121, dual , 2ohm (€50/$70 NOT UK)
Cathul
Germany
Peter
Ford Mach-E
The Dayton RSS265HO-4 is a single voice coil subwoofer driver.
The Dayton RSS265HO-44 is the dual voice coil version that needs a much larger enclosure.
m3incorp
Georgia/Colorado
James
The one I have is the JL10W1V3-4, it's a lot better than the one you listed and cost about twice the price.
Just to help people out here are a few measurements. remember 267mm will fit inside the ridges and about 277 inside the main recess.
Inner hole size, outer size, depth, sensitivity, dual or single coil (all 4 ohm)
Pioneer TS-A250D4 - 230 , 267 , 77, 133, dual
Dayton RSS265HO-4 - 230, 267, 87, 137, single (EDIT)
m3incorp
Georgia/Colorado
James
If anyone wants the JL Audio 10W1V3-4 that I have, I will sell it for $180 shipped since I don't have it hooked up. They are $210 in the stores.
Gregs24
Gregs24
Greg
I've added it to the list. I would have to say I am very pleased with the Pioneer at ÂŁ70 but it is obviously up to the individual what they are prepared to pay. I have added an idea of UK prices to the list to give a flavour of the cost.
Gregs24
Gregs24
Greg
Dayton RSS265HO-44 is dual 2 ohm but added to the list
Cathul
Germany
Peter
Ford Mach-E
mikes2017gt
San Antonio, TX
17 GT Prem M/T 3.55
Not according to the specs at Parts Express...
https://www.parts-express.com/dayton-audio-rss265ho-44-10-reference-ho-dvc-subwoofer--295-463
According to Parts Express it's dual 4 Ohm.
Don't get me wrong, but if people buy them thinking they can get 4 Ohm by connecting the voice coils in series they will wonder why they don't get the output they want afterwards...
Yup. A dual 4-ohm driver will get you an 8-ohm load wired in series or a 2-ohm load wired in parallel. No other ohm loads are possible. Unless you totally screw it up and only wire 1 voice coil to the amp. :shock: Then you have bigger problems to worry about!
Gregs24
Gregs24
Greg
You are correct.
It's a rather confusing bit of identification. It clearly says 2 ohm in the title but dual 4 ohm in the information. Other companies don't describe similar speakers that way.
http://www.daytonaudio.com/product/1108/rss265ho-44-10-reference-ho-dvc-subwoofer-2-ohm
cosmic charlie
Sunny Florida and Taxachussettes.
2019 Steeda Streetfighter Q850 NEED FOR GREEN, 2016 Focus RS (frozen white), 2016 Focus RS (stealth grey), 2014 Ford F150 Crewcab, 2015 Porsche Boxter GTS, 2013 Mercedez Benz ML350, 2003 Mercedes Benz C32AMG, 1989 Honda CRX Si Turbo
The Pioneer is 70.00 on Amazon. Can't go wrong there!
cosmic charlie
