Anyone using Sai Li fuel system?
venumous
PA
16' Procharged GT
Made 770whp on Sai Li on Mustang Dyno, ID1000s with boost reference. My car had all kinds of issues before I retuned to AED and went boost referenced. Trapped over 138mph leaving at idle on stock clutch and axles.
MidnightGT
AR
2015 GT
For what it's worth, I've installed 2 Sai Li kits on two different s550's. The second kit was running out of fuel in the low 700's even though everything appeared perfect. Come to find out it was a bad ground. Don't know if that's been addressed or looked at, but may be worth checking.
Tommy V
Brookly park Md
Tommy
That's funny u brought that up as I did change my ground because I though it may be an issue,but I ran aall the ground wires back to very back panel where the factory uses two grounds.I really thought it was the ground too.but I checked for voltage drop and ohmed the ground wires out.
dubster99
Nor*Cal
2015 Ingot Silver GT PP
You said it's been super cold there. When was the last time you tested your e85 to make sure it's still e85 and not a winter blend?
SolarFlare
S. Fla
2015 CO GT
You would think that would be better in his case, winter blend is more gas, less ethanol.
Tommy V
Brookly park Md
Tommy
Yes true,I would be having problems with knock if the e85 was less,but the station I get it at is where everyone goes because the guys is a big VP racing fuel station and sells ei85 all year round.I have never tested it,but everyone gets e85 their.I.really want to try running a boost reference,because it seems like most of the guys not having problems are running their system like this,I did bump the fuel pressure up from 58 to 65 per Lund and it helped a little bit but was still coming up a little short.
RubyRedBoost
Traded EB old name New GT
Fort Worth
Josh
2015 Guard GT with PP
I logged mine just to be safe and was at .76-.78 all the way to 7800. I'm seeing around 14-15psi at peak. Fuel is fine on mine at 55psi fuel pressure and no vacuum ref.
dubster99
Nor*Cal
My pressure is set to 50psi at idle with vac hose off. When the vac hose goes back on it goes to 40psi. The 20" of vacuum means -10psi at idle when you hook up the boost reference. My lambda actually gets richer at the high rpms...goes to around .76-77 from .79.
[MENTION=12860]RubyRedBoost[/MENTION] what kinda power are you making on the 3.48?
Travis@boostworks
Katy, TX
www.boostworks.com
2015 Mustang GT
We've made right at 780whp and the GT350 pumps are done on our turbo cars. Adding a single BAP to one of the pumps gets you 850-875whp. Twin bap gets you around 950-1000.
The GT500 pumps flow more than the GT350 pumps. So, that hat is going to make more.
RubyRedBoost
Fort Worth
Josh
Car made 769/581 on e70 spinning on the big end. Which is why he let out at 7300 istead of taking it to 7800. So theres more in it. My ET streets were bald. I put new et street Rs and plan to re-dyno soon. I'm happy either way with this combo.
Tommy V
Brookly park Md
Tommy
U .cant compare e70 or e50 to e85 theirs a big difference when it comes to fuel trims between them.Now the e50 e70 will still give u good power and knock resistance but a car with less ethanol will run richer.
RubyRedBoost
Fort Worth
Josh
I'm aware of that. Just sharing my experience
RubyRedBoost
Fort Worth
Josh
Pump e85 at Racetrack in Ft Worth has tested e70 lately
Tommy V
Brookly park Md
Tommy
Is there E50 and E70? Or, are you guys mixing your own fuel?
We have E85 (which is actually more like E90 here).
Yes most stations here are forced by law to run winter blends of anything from e50 to e70,to be honest on all the pumps here it's says mimamal 50%ethanol.There are a few stations that will have e85 all year round but very few.Most regular stations in my area are know to have only e70 most of the time.
