Anyone using Sai Li fuel system?
Tommy V
Brookly park Md
Tommy
Well put the bap on today and ran it up to 7500 rpms and fuel held good,he had. 79 commanded and it was .80 at 7500 rpms.Just going to run the bap for a little while and then put a dw 400 pump in the hat.
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Try swapping the bap to the other pump and see if you get the same results.
Tommy V
Brookly park Md
Tommy
Correct 17 volts to both pumps,now I'm going to do a boost reference.
Rcobra427
Fort Lauderdale, Florida
2017 Mustang GT
Maybe a stupid question but I’m supercharged (first supercharged car) what do u mean by boost reference and how does it work, looking into doing a sai li type of set up
Tommy V
Brookly park Md
Tommy
It's a vacuum line ran to your fuel pressure regulator.When boost comes in it raises fuel pressure,for every pound of boost it raises fuel pressure 1 psi.
venumous
PA
16' Procharged GT
gqneon
Westfield, IN
18 GT PP / Manual
Is Sai Li active here at all? I've been messaging him on Facebook messenger since Sunday morning and he hasn't responded. Kind of hard to make a purchase decision like this - because I've heard great things about his kits. Anyone have a better way to get a hold of him?
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
We're a distributor for Sai so if you have any questions or would like to place an order for a system please feel free to give us a call. We're here to assist you.
Thanks, Jared
mustangmike86
fl
2016 mustang gt PP
Thanks, Jared
Hi, I would like a little more information on sai li fuel system. I am looking for a system that uses mostly steel braided line for the complete system, does this sai li kit utilize the factory supply line then steel braided for the return, or does the kit adapt the factory quick connect to AN line?
dubster99
Nor*Cal
It uses the factory feed line for delivery, and a push lock non braided hose for return.
Rcobra427
2017 Mustang GT
Where does the regulator go into the system? does it have an adapter for the factory fuel feed line or does it go on the return side of the rail
dubster99
Nor*Cal
The feed line attaches to an adapter, which attaches to the rail. The adapter has an AN fitting in it for a hose that goes to the regulator.
