dubster99
[MENTION=9456]Tommy V[/MENTION] , let me know how you like your hoses/etc from an fittings direct. I've heard mixed reviews on their quality.
Cutting it while wrapped in masking tape helps a lot, then keep the tape on it when you put the capture nut through, once it is through you can remove the tape, trim any frayed edges and tighten the capture nut to the fitting...if you have heat shrink large enough it will make sure nothing frays when you cut it with a dremel too. sometimes the tape will lose tension and it starts to fray a bit, which is anoying...I had to re-do a few cuts bc of thatLike Ken said the hose was good quality.It does take a little practice cutting the brading back and getting the fittings right but it's not that hard.Im done with tuning for 93 the good stuff is next.
Yeah.. that guy legit copied Sai. He bought a Sai kit and then started selling his "own" kit a couple weeks later.
But this kit uses a ford fuel pump driver module. It looks to be more of a true plug and play system. Sai Li kit you have hook up a relay and run some wiring.Yeah.. that guy legit copied Sai. He bought a Sai kit and then started selling his "own" kit a couple weeks later.
Hey if this is the case,were not using the stock fpm and their is no pressure sensor on the gt rails,so when u put the gt350 pumps in how does the ecu know how much voltage the pumps need??I ask this because I'm 10 tuning now and Jon said I'm running out of pump at 7k and no where near 800 whp.GT350 pressure is regulated by variable pump speed as they have a fuel pressure sensor on the rail.
I think its because GTs use it as a return style setup, regulated by the FPR back to tank. Otherwise we would need to use dual FPDMs like the shelbys.Hey if this is the case,were not using the stock fpm and their is no pressure sensor on the gt rails,so when u put the gt350 pumps in how does the ecu know how much voltage the pumps need??I ask this because I'm 10 tuning now and Jon said I'm running out of pump at 7k and no where near 800 whp.
I would agree to that except all my logs 6 total have had perfect air fuel until the last one,pumps are wired wright,did check connections just to make sure no loose ones.Also the way the stock line runs and is made it's almost impossible to kink,unless your an idiot lol.So Lund is off for the holidays so I have to wait to figure this out.Using GT350 pumps in the GT with a return style system you don't regulate the voltage with the PCM. You run the pumps at bat voltage and regulate pressure with the regulator.
If you are running out of pump there is something wrong. You either have an install problem (voltage, kink in hose, etc) or a pump is dead or the polarity is reversed on one of the pumps (check wiring).
If they have all been good until the last one, double check everything. Triple check fuel pressure with the vac hose off, see what it goes to when you reattach the hose. Check wiring and fuses for both pumps to make sure they're still both operating.I would agree to that except all my logs 6 total have had perfect air fuel until the last one,pumps are wired wright,did check connections just to make sure no loose ones.Also the way the stock line runs and is made it's almost impossible to kink,unless your an idiot lol.So Lund is off for the holidays so I have to wait to figure this out.
Are u running a boost reference on your regulator,I'm seeing some guys saying their tuner requires it and others that say set it to 58 and no vacvum.Using GT350 pumps in the GT with a return style system you don't regulate the voltage with the PCM. You run the pumps at bat voltage and regulate pressure with the regulator.
