I'm a believer that fixed back seats without a 5 or 6 pt harness/rollbar is pretty dangerous in a roll over or crash.
wow! looks great, how much did the set run you if you dont mind me asking?If your willing to spend the extra $$$ I would always suggest Recaro. Personally.
They are the Recaro Profi XL and they are around $1000 each if I recall correctly. Theres alot of fakes out there though so be cafeful and make sure you get them from a reputable source.wow! looks great, how much did the set run you if you dont mind me asking?
Mine are the US version, and I fabricated my own floor brackets using the sparco side mounts with them flush against the console, which has about 2" clearance on outside.Are those the "evo II" or "evo II us". I am a 38" waist and the us version is a little wider than the standard evo II. I only ask because I have heard the us version doesn't fit against the center console. Whoch version do you have? Did you have any fitment problems?
Don't know, the Sparco website shows them all with the white liningBEAUTIFUL! Why does your Evo 2 have the white lining and some don't?
Nice doggie, my favorite breed.If your willing to spend the extra $$$ I would always suggest Recaro. Personally.
More dangerous than running a 4 or 6 point roll bar on the street? In my experience I have seen more injuries caused by aftermarket roll bars on the street and even the track than I have injuries by actual rollover over accidents. Unless you are talking about a car specific custom cage on a car that’s only tracked.Fixed back seats without a proper roll bar and harness are not really safe in an accident.
If you can afford it, use a proper FIA seat like a Sparco or Recaro. I personally prefer Cobra seats as they are premium and have better value. Cobra is made of composite (carbon/kevlar) material and is the same price as Recaro/Sparco (which is made of fiberglass unless you get high end models). Cobras have better fit and are more comfortable for long drives as well (IMO).
Either way, use proper safety when using fixed back seats.
Have fun and be safe!
:amen:
.I’m very sorry to hear you had an incident on track. That’s never a fun experience, and unfortunately can happen to the best of us.Here's what the steps are for a safe setup.
For a person that doesn't want a roll bar and to keep airbags I highly recommend the schroth quick fit. It has asm technology so that it in an accident you don't slide underneath the belt strap.
With that setup that's all you need.
Now when you get a fixed back seat this is what you need for a proper setup.
HANS device
Removal or deactivate airbags
Fixed back seat and brackets
4 point roll bar minimum
6 point hans complaint harness
In an accident with the oem recaro while using the oem belts or schroth. The seat will collapse backwards in a roll over.
In an accident with a fixed back seat and no roll bar you run the risk of getting crushed in a rollover.
This is why harness bars are useless because they offer no rollover protection and prevent your seat from going backwards in a rollover.
I've done both on multiple cars, one actually ending up in an accident on the track.
Doing it right saved my life.
I agree with XXANCHORMANXX.In a roll over a 6 point harness will keep you pinned. There is no way you can move out of the way of a caving in roof.
With the oem setup the 3 point belt will allow your body to roll out of the way.
I've had harness bars in the past.
Typically there are two reasons why someone would install a harness bar instead of a roll bar.
1. Cost
2. Install difficulty
When choosing a roll bar for a street car you want to look for ones that sit further back behind you.
You won't catch any race car driver dead with a harness bar instead of a roll bar at a minimum.
I'm unaware of any racing event that would allow someone to pass tech with a harness bar, fixed back seat and 6 pt harness
If you're going to do a fixed back seat with a 6 point harness a roll bar at a minimum is the way to go.
Most people try to justify their reasoning due to cost. Do it right or don't do it all.
If you understand how seat belts work, 3/4/5/6 pt harness works, then it should be pretty clear why having a fixed back seat sans roll bar is not safe.
But hey its your life.
