5.0 Dyno Chart Compilation
Aubrey
GT4949
Sydney, Australia
Planning the next one!
Stock Aussie 2017 GT.
Reading in kw/nm
Dyno was reading about 10% down from “normal”.
My torque looks low, and is lambda right?
Thanks!
Burkey
Australia
256 KW = 343 HP. Seems low ... if it was 10% higher it would be around 377 HP (281 KW).
Lambda info. Lambda of 0.7 might be slightly rich
http://diagtools.lv/soft/Lambda_eng.pdf
Stock Aussie cars make 306kw at the flywheel (poor header design in the conversion process and slightly lower octane fuel).
250 (ish) kw at the tyres is fairly normal for a manual. Some dynos read 230, others show 280.
If you can lose only 26kw (30hp) through the drivetrain, there’s some magic going on.
bakerjd
North Carolina
Josh
Put me down for 1024whp/827ft-lbs. Pull done on a Mustang Dyno. 2018 Stock engine. Armageddon Twin Turbos.
Aubrey
GT4949
Sydney, Australia
Updated, and looking far more realistic! Guessing at 20+ rwkw gain over stock based on this dyno.
gqneon
Westfield, IN
18 GT PP / Manual
2018 Mustang GT 6-speed Manual
Stage 2 Gen 5 Whipple, Pypes longtubes, ID1050x, pump gas, Lund tune
Stock pulley size (3.875" - about 9-10psi)
Pulls 1 and 2 were to about 7k, pull 3 was to 7500 rpm
Platinum_5.0
Edmonton, Canada
Daniel
2021 10R Whipple
2017 GT 6 speed. Gen 3 stage 2 Whipple. Longtubes, 3.6 pulley and 94 pump fuel. Rob Shoemaker tuned.
18RTRSpec2
Baltimore, Maryland
Adam
2018 Mustang RTR Spec 2 A10. 2016 F150 4Wd 3.5 Ecoboost. 1993 Cobra teal. 1986 Mustang GT
2018 RTR Spec 2 NA A10 Mods: Jet Hot 1 3/4 Long Tubes, DSS Driveshaft, GT350 DS axle, 3,73s Torsen Cast Iron center section, Rev Auto Flex Fuel tune on E85
The 457 rwhp run was with the stock air box. 468 rwhp with the GT350/Bullitt cai. Still through the factory resonator and mufflers.
Thanks!
AZ18yote
Arizona
Bryan
Enoch
UK
Andy
Guard 5.0 (Auto) Fastback, Saddle Leather
2016 UK mustang GT
2018 inlet manifold
Longtube headers
Roush CAI
Borla catback with 200 cell cats
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
Added JLT Cold Air (which is sort of a pain to fit) and a bama rev-x tuner with a 91 oct performance tune. Went from 419 to 445. Not bad? :)
So you have a 2018 manual, and only mods are the JLT CAI and Bama tune, and you jumped from 419 hp to 445 hp? That's really good, I haven't seen an increase like that on other 2018's with just the intake and tune. What were your torque numbers like? Did you gain any more torque down low?
fMErunnin
St Louis
2018 Mustang Gt
445hp/ 402tq. I am overly impressed. Did not expect those numbers. It is also for sale lol.
