4G Modem Disabling Instructions:
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
Yes, that's the one. Pull the wiring/data harness. For good measure pull out the two coaxial leads too.
You will get no CEL lights, but a scan will show diagnostics in relation.
Pull the plugs!
any idea how to pull the coax leads? clips do not appear to release by pressing
Tomster
Beware of idiots
Tom
I don't recall off the top of my head. It didn't require any special tools. Take a picture to refresh my memory
Tomster
Beware of idiots
Tom
Vague memory..... a small screwdriver to release a small tab??? I recall it was fragile and can break, so be careful.
Tomster
Beware of idiots
Tom
And I thought i had something about it in my writeup a long time ago.
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
I went back and searched and found some comments on it. I had originally just unplugged the main data cable and left the coax connected as I just couldn't get the clips done. It was on my list to recheck the car after I got it back from the body shop and sure enough they had it reconnected again. It's in such an awkward spot that it's hard to get a good view of the cables from the back side. I guess I could have removed the modem from the mount, but ended up just unplugging the main data cable for now.
I think that should still suffice in getting it to stop communicating...
Tomster
Beware of idiots
Tom
Unplugging the power/data harness is sufficient enough to stop data transfer. It's like pulling the power plug on your home modem.
Tomster
Beware of idiots
Tom
You will get scan codes if you use a scanner, but not a CEL light. When you hook a scanner up from time to time, just rest the DTCs pertaining to the telemantics
526 HRSE
California
2017 GT350 Grabber Blue
Is this just 2018/2019 and up?
Prodigal
OKC
2021 Mach 1
Prodigal
OKC
2021 Mach 1
Well, if I knew it was going to be that kind of party...
I suppose if we need to be sure we can pull the modem out, smash it, light the parts on fire and dance around it. It's the only way to be sure.
I like the way you think!
Tomster
Beware of idiots
Tom
All you have to do is pull the power/data harness and be done. No need for drama.
