2018 GT PP2 Rear Differential Overheating Issue
MadDog
San Marcos, CA
2019 Ford Mustang PP2 with Triple X-Pipe
EFI
Masshole central
5.Br0
The German company name is FluiX. A small company with a handful of employees. I hope the fin-cooled diff cover works as good as it looks.
https://www.fluix.de/product-page/differential-oil-cooler-cover
For half the price of a regular pump & heat exchanger kit it's worth trying, and if it does what it says then that's a solid improvement and enough to keep it out of the danger zone and get most people to the end of the session.
TeeLew
So Cal
Tim
Does anyone have the AL housing or do we all have the cast iron one? I'm curious if it cools any better.
EFI
Masshole central
5.Br0
Autos have the aluminum, manuals have the iron. Iron holds heat a bit better, but you won't notice a discernible difference between the two.
mustang5o
Middle America
2023 Oxford White Mach 1 Handling Pack
TeeLew
So Cal
Tim
Make it out of Mag!
FluiX
Munich
2019 Mustang GT
I have seen that people show interest in the differential cover here, but people are hesitant since they are not sure if it works. In this thread in the link @JohnVallo tested the cover. I sent him one cover exactly to prove that it will lower the temperatures.
https://www.mustang6g.com/forums/threads/rear-diff-cover.146310/page-3#post-3084920
In my view the test was successful, even if there are some requests to do more thorough testing etc, which Ford did not even do on the early GT350s. The drift session John did should give an idea that the temperatures will remain in the safe range.
Champracerj
Webster NY 14580
Jay
2018 Mustang GT PP2
Thank for the post, link and results. great contribution to the topic.
It does look like a reasonable solution for some usage with about 20 degree drop in temp under the more severe conditions tested. 275 to 255.
For real severe usage I'd go with the cooler as several have reported a 40 degree drop in temps. 275 to 235.
Cover: cost is favorable, no wiring and hyd plumbing. Must drop the rear to install.
Cooler: Requires wiring, hyd plumbing and mounting pump and cooler. Higher cost.
Choice is good.....
Porsche Dude
North Vancouver BC Canada
Bob
2019 Mustang GT PP 2, 2004 Porsche Boxster S
Choice is good.....
What size tires are you running on the track? I am thinking of going down to an 18" Apex Wheel and real slicks, and seeing you are running track a lot, I am curious. Thanks.
Champracerj
Webster NY 14580
Jay
2018 Mustang GT PP2
RE71 305/30/19 square because I use my car daily and drive to the track. Slicks would be nice but increases the hassles....
shogun32
Northern VA
I picked up 18x11 Flowform F2 for 30% off in order to run used slicks on the back. I don't know if they'll fit over the 6-pots up front.
Porsche Dude
Bob
Apex makes wheels that fit the PP2 up front that don't touch the brakes. I am looking at the used slicks. How wide are you and are you running the square set up? Thanks.
Brazos609
2015 GT Premium PP Recaro
