10R80 issue Mach 1
Machgzus
Kansas
Dustin
2021 Mach 1 hp
So I thought I'd share a recent issue i had with my 21 A10 Mach. It started shifting incredibly hard from 4th to 5th under light throttle, I mean it slammed into 5th. Under heavy throttle it would flare between 4th and 5th. I began experimenting with the other modes and going between drive and sport, finding it only did it in my mode and only with shifter in S. I finally fixed the issue by resetting my mode, now it shifts like butter. Just thought I'd share in case anyone else runs into this.
Mach_1
United Kingdom
Ford Mustang Mach 1 2022
I’m having mine relearned on Monday, same issues. Keep you poated
Machgzus
Kansas
Dustin
2021 Mach 1 hp
Try selecting new options in my mode and make a new one. Fixed mine
Mach_1
United Kingdom
Back from gearbox relearn and seeing great results, smoother gear changes on deceleration especially from 5th to 3rd. Happy days.
diskodan550
I95N
2022 mustang mach 1
How'd you go about the relearn? FORscan or battery reconnect? I definitely need to get mine set.
Mach_1
United Kingdom
Forscan relearn then drove the car for 30 mins going up and down the gears automatically, drove in normal mode all the time. Normal drive style, no racing. Gearshifts jumpy at first 10 mins then got better and better by the time I arrived back from the trip it was 100% better, 45 mins driving in total. Keeping the car now ;)
diskodan550
I95N
2022 mustang mach 1
Nice! This is good news. I was also starting to give up on this pony. Forscan sounds like a plan. 😏
Charlemagne
Czech Republic (Europe)
Nick
There were several TSBs for issues with 10R80 such as hard shifting, do you have the latest software and other stuff to fix any issues with shifting? Seems often people rely on magic and feelings instead of fixing it the proper way.
Mach_1
United Kingdom
My 2022 had the tsb carried out one year after registration. 22/10/2023. Interestingly the gearbox oil was topped up 6 months prior to the tsb
DougS550
Fishers, Indiana
Doug
IMHO, unless their was a design change from my 19 A10 and later, my QA1 works perfect. So, their must be an alighnment issue from the rear transmission to the front pinion, l would track it out. Good Luck to OP
GT-SV
Silicon Valley
2022 Mustang Mach 1
Dealer just did TSB 26-2226 under warrantly on my 2022 Mach 1 10 speed. Anybody else have that done?
Note: per TSB applies if "Built on or before 15-Aug-2022 "
Ohio_Pilot1980
Mid Ohio
Nathan
2023 FJG Mach 1 Non-HP, 2018 F150, 2014 SHO
Interesting, mine did some incredibly harsh shifts in 5th the other day, checked for TSBs and found this. Seems like my dealer is going to drop the pan and check for silt.
GT-SV
Silicon Valley
2022 Mustang Mach 1
^ Let us know how that turns out, hopefully tsb fixes harsh shifts.
MidnightStars
North PA
Some 6R80s do the same, mine included. Disabling the adaptive shift, and/or relearning fixes it. The TSB Ohio_Pilot1980 mentioned is worth having checked out.
