You're in charge!
CooterK
Bay Area, CA
2015 Ingot GT PP
Only thing on my wishlist for '16 would be rear Brembo calipers. If not only just for aesthetics...
For '17-18 I would fully expect to see the 3.5l ecoboost available. As much as 500 HP and 500 ft lb tq.
EngineerDave
Florence, KY
2015 Mustang GT Premium, 401A + Extras, 98 F-250LD
I really don't care what year they include it, but I really want to see high beams like those that BMW recently showed off. They use some sort of laser system and even though your high beams are on, they do not blind oncoming traffic, while still maintaining the field of view from highs.
I would love for them to get 100hp per liter on the 5.0. I suspect they can do it, it's just a matter of time. It would also be nice if they included a supercharged or Ecoboost 5.0/5.2/5.4 that's covered under warranty from the factory.
I expect the backend will be the first thing revamped along with a CS style grill at some point. The standard GT badge on the rear is just so boring.
Grimace427
NoVA
2011 Mustang 5.0
Base GT Track Package
  • Base model only, manual transmission only
  • 5.0 Coyote, air/oil cooler, billet oil pump gears, FRPP tune, 7,000rpm rev limit, FRPP exhaust w/side exit
  • Upgraded Getrag transmission, V160 perhaps, solid mount shifter, CF driveshaft, upgraded clutch, lightened flywheel, CJ pulse ring, Torsen T2-R/T4-R diff, choice of rear gear ratio
  • Adjustable shocks/struts, smaller OD springs for increased wheel clearance, standard poly bushings everywhere, AL strut tower to firewall brace
  • 14"(not a typo) two-piece brake rotors, 6-piston lightweight calipers front, 13" two-piece rotors with 2-piston fixed calipers rear, stainless brake lines, hardware for mounting ducts(owner installed)
  • 18" forged/rotary forged wheels, 10" width minimum...tires TBD
  • Central hood vent for cooling and aero, more aggressive front splitter, fully functional rear diffuser, rear wing/spoiler TBD
  • Standard Recaro seats, rear seat delete, flat bottomed steering wheel, oil temp/pressure guage
  • $7,595 MSRP
  • Save money over the GT350 by not having the FPC Voodoo, Magnaride, Tremec, 15.5" Brembos, 19" forged wheels, Collectability/ADM
GT Drag Pack
  • Manual or Auto
  • 5.0 Coyote with billet oil pump gears, forged pistons, FRPP tune/7,000rpm limit, CJ pulse ring, upgraded fuel system
  • Manual trans: upgrade clutch, shifter, driveshaft, axle shafts
  • Auto trans: higher stall converter, factory trans brake via software, driveshaft, axle shafts
  • Poly/solid rear bushings
  • Choice of gear ratio, Wavetrac or other drag-oriented diff
  • Lightweight base brakes, single piston calipers front/rear, increased rear tire clearance
  • $3,495 MSRP
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
[/LIST]GT Drag Pack
  • Manual or Auto
  • $3,495 MSRP
Yes, please.
Stonehauler
Delaware
F350, 550i
2015
V6 base
EcoBoost base and premium
GT base and premium
2016 - new Sync system, PP available with auto for GT
V6 base
GT base and premium
GT350, GT350R
2017 - 10 speed standard
EcoBoost Base and Premium
GT base and Premium - possible DI
Possible GT California special
GT350 GT350R
2018
ECOboost Base and Premium
If no DI for GT in 2017, V8 is replaced with EcoBoost V6 making 480+ HP
Mach 1 or GT500 introduced. Either N/A 5.2 FPC or EcoBoost 5.2 FPC making 700+ HP Possible V6 EcoBoost V6 with 600+ hp.
2019
Ecoboost Base and Premium
no more V8 GT unless significant investment was made in 5.0 EB. V6 EcoBoost instead
Mach 1 GT500 continues unchanged
2020 - refresh
GT EcoBoost V6
The "I can't drive 55" anniversary package
SuperSnake/Cobra edition
zackmd1
Zack
2015
V6 entry level
EcoBoost 2.3l
GT 5.0
2016
V6 entry level
EcoBoost 2.3l
GT 5.0
GT350, GT350R 5.2 voodo
2017
V6 entry level
EcoBoost 2.3l
GT 5.0
Mach 1 5.0 DI
GT350 GT350R
GT500 600hp EcoBoost V6
2018
Refresh: 10 speed Auto with facelift similar to 13-14 generation
EcoBoost 2.3l now 330hp
GT EcoBoost V6 3.0 based off of the "nano" 2.7 with around 475hp
Mach 1 5.0 DI
GT350 GT350R with updated 5.2 voodoo
GT500 Ecoboost V6
2019
EcoBoost 2.3l 330hp
GT EcoBoost V6 3.0 475hp
Mach 1 5.0 DI
GT350 GT350R updated 5.2 voodoo
GT500 Ecoboost V6
2020
Mid cycle refresh: Bodywork with new aluminum and carbon composite construction
EcoBoost 2.3l 340hp
Hybrid 1.0l EcoBoost with electric drive ~365hp combined with ~150mpg
GT EcoBoost V6 3.0 500hp
GT California Specical or similar with 3.7l "nano" V8 EcoBoost 535hp
GT350 GT350R Ecoboost V6
supersnake94
Notheast
2010 Ford Focus SE
2016:
V6
Ecoboost
GT
GT350/GT350R
Automatic cars have a 10 speed automatic
2017: Minor design refresh
V6
Ecoboost reworked to get 320 HP and cylinder deactivation.
GT with 5.0 with Direct Injection and Cylinder Deactivation, 450HP
GT350
GT500 5.0 Ecoboost V8 680HP and will include a limited edition package like the 2015 50th LE models with 1,967 worthy buyers of that package.
7 speed manual transmission across the lineup.
2018
Ecoboost is base car
GT
50th Anniversary California Special for GT premium
Bullitt
GT350
GT500
GT500KR with a reworked 5.0 Ecoboost V8 to produce 725HP this will be a limited edition car with only 1,968 being built.
2019
Ecoboost
GT
Mach 1 with 5.2TT Voodoo
GT500
2020: Major design refresh
Ecoboost
GT
Mach 1
GT500
Craiger
St. Louis
2015 Mustang V6
Maybe in 2020 do a major redesign refesh with a front wheel drive base V6 Coupe with better gas millage. Have leather and a sunroof as an options for the base V6 Coupe. Also have an all touch screen digital dash were the speedometer and RPM were digital along with a HUD. No nobs at all in the dash the radio and air conditioning controls would be all touchscreen. Include the touch screen sync in the all digital dash. Maybe not even have a CD in the car. Everything would be cloud based. Keep the GT as reel wheel drive.
Potrillo
DFW
2015 DIB GT Premium
Why would they go through the trouble of such a drastic redesign and have a split platform? I don't think the numbers would support such a move.
cush
Littleton, Colorado
2015 GT Premium with PP, Guard Metalic
2016:
Dual Clutch Gearbox
New color pallet
I4 becomes base engine
Turbo V6 becomes midgrade 380 HP
GT 5.0 goes direct inject, and with upgraded intake and exhaust makes 500HP
2018
New/updated front and rear fascia
New roof line on coupe to allow Sun/moon roof
2019
Last year of body style, only very minor changes...
Upgraded suspension to include magnetic ride control... carries over to new model in 2020
2020:
New model!
All wheel drive option introduced
590 HP twin turbo Rogue Coyote 5.0 (why not make up a name while I'm pulling things from my ass)
All Aluminum chassis
Carbon fiber and aluminum body panels (that fit)
Transaxle for rear and all wheel drive variants
I deliberately did not get into GT 350 & 500....
SkapeGote
Canada
1997 f150
I would do this:
2016: Do a version called the 5.0 Fox or Fox 5.0. A stripper version like the old LX cars.
2017: Flux Capacitor
Done
Conedodger
Ca
2017 GT350-R
2015
GT350 released early (July 4th). Advertised to make 520 hp.
Customers dyno cars and make 500 at the wheels.
2016:
Mach 1 released. DI coyote motor 450hp 7,500 fuel cut, 2 piece brake rotors standard. 19 x 10 wheels.
Eco boost gets 10hp boost and torsion LS.
2017:
GT500 released. Twin turbo 5.0 makes 700hp 700 torque.
duel clutch paddle shift 8 speed 11" wide wheels 315 all around.
2018:
5.0 gets FPC 7,600 fuel cut 540 hp 500 torque. Ford developes first flat DC motor/flywheel 6 speed combo. Adds 1.5 kw lithium battery eliminates 12v battery and conventional starter motor.
Creates first mustang that uses this technology to create an affordable GT car that gets 35 mpg and can run the quarter mile in 11.99 seconds.
Twin Turbo
Twin Turbo
Super Moderator
Moderator
England
Paul
Mustang '05 GT
Some great ideas guys, keep 'em coming!
Supersnake94, I think you and I think along similar lines :thumbsup:
2016:
V6
Ecoboost
GT
GT350/GT350R
V6
GT350
2018
GT
Bullitt
GT350
GT500
2019
Ecoboost
GT
GT500
Ecoboost
GT
Mach 1
GT500
