SolarFlare
"custom inhouse dyno tuning"......no thanks.
I don't doubt there work. They told me I could use the procharger tuning if I wanted. I like the idea of a dyno tune over a over the internet tune."custom inhouse dyno tuning"......no thanks.
If you are never going to hit rev limiter or hit 2step, opg/cs is not necessary. Very good to do, but gen3 has a slightly better opg and its fine unless you apply vibrations. Im currently ess and stock opg/cs, no isssues. Im planning on doing it in years when i want to do a whole timing upgradeI want to do the ESS kit as well. I just don't want to go through the trouble of doing opg/cs.
What kinda power you making on that? Stock cats?If you are never going to hit rev limiter or hit 2step, opg/cs is not necessary. Very good to do, but gen3 has a slightly better opg and its fine unless you apply vibrations. Im currently ess and stock opg/cs, no isssues. Im planning on doing it in years when i want to do a whole timing upgrade
Good to know!If you are never going to hit rev limiter or hit 2step, opg/cs is not necessary. Very good to do, but gen3 has a slightly better opg and its fine unless you apply vibrations. Im currently ess and stock opg/cs, no isssues. Im planning on doing it in years when i want to do a whole timing upgrade
I still need to dyno, but im catless headers, 120mm pulley on 93 pump gas. Should be making in the area of 680-700whp.What kinda power you making on that? Stock cats?
What's it run?If you are never going to hit rev limiter or hit 2step, opg/cs is not necessary. Very good to do, but gen3 has a slightly better opg and its fine unless you apply vibrations. Im currently ess and stock opg/cs, no isssues. Im planning on doing it in years when i want to do a whole timing upgrade
No idea. I daily drive it, mainly do street rolls for fun. I can hardly afford it without the racing costs haha. Try the ess thread, there are many there that do race and can give you all their numbers running similar setupsWhat's it run?
