winter storage
kent0464
Virginia
Kent
1983 Ford Ranger, 1986 SVO Mustang, 2017 Mustang GT PP, 2017 F150 3.5 Eco
Hi guys, first time mustang 5.0 owner and first time storing a car over the entire winter. Ill be storing my 2018 10 speed PP1 in unheated indoor storage. What are somethings I need to do? Oil change before or after? Fuel stabilizer? How full should I leave the tank? Battery in or out? Trickle charger may not be an option depending on the location I am able to get.
Thanks in advance for any input!
I see you’re in Canada, I’m from Alaska, so I know your unheated storage is going to be cold! Make sure the antifreeze is good! Put the car on jackstands. Either drain the fuel tank or use stabilizer. Pull the spark plugs fog the cylinders, then put the plugs back in. Pull the battery and keep it in the house. If all that is too much then plan on starting the car every week to 10 days.
When summer comes, fuel it back up, put a can of SeaFoam in the oil, idle or run for 20 min or so, then drain the oil while she’s warm to get all the crap out, fill her, check all the fluids air pressure etc and have some spring fun.
Airborne5.0
Ontario
Thanks for the replies guys. As the storage date (20 Oct) gets closer I am preping what I need. I changed the oil in April and its only been driven 4,000 KM's (2.5k Miles) since then. The storage location is 1 hour away. Should I change the oil before and after storage? Or would I be ok putting away with the current oil, driving it home in the spring (1 hr) and changing it then?
Thanks guys
Monopoly
Toronto
2017 Mustang GT, 2012 Civic Si
Thanks guys
Your probably fine to leave it. I change it right before you store it in October and only drive 4-5k kms a year. Clean oil before storage.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I follow most of the recommendations of others, except I just follow the oil minder for oil changes. I wired in a pigtail to fusebox +12v and ground at the right side shock tower so that I can plug in my cheap HF battery tender.
Also, since I have track wheels and daily wheels, I put the track wheels on before storage in my unheated garage. Tire Rack told me that I don't have to worry about cracking summer tires out in the backyard storage barn, but I don't want to take any chances.
I also call my insurance company and convert my policy to "storage", which pro-rates out to about $10/month!
I wanted to replace my rusted out 2001 minivan for a nicer winter vehicle, but it runs by throwing a few cheap parts at it occasionally. Besides I put that money saved, plus my 2016 trade-in to my awesome new 2019. So yeah, it's feast or famine with my two very different vehicles. Winter sucks, period.
Monopoly
Toronto
I follow most of the recommendations of others.
Thats exact it. I got my winter storage tips from a guy who owns 50 Classic pre-1970s cars in a museum out in Nfld lol.
Airborne5.0
Ontario
Hi guys, thanks all of the info contributed to my post. As of now I am planning on:
- Full tank of highest octane gas I can get with full stabilizer
- Carpet pads for tires
- Air pressure change, what do you guys put the air pressure at, your numbers?
- Bounce sheets
- Remove the battery and store in my house
Question about the windows. For those that remove the battery, what do you do about the windows? Do you roll them down slightly? With no battery in how can I open the door, to open to the engine bay to put the battery back in?
lacanteen
Louisiana: Cajun Country
George
If you leave the doors unlocked they will open fine. The little jog it does with battery power is to help seal the window. You can unlock the door manually with the key found inside the key fob if you must lock the door.
Airborne5.0
Ontario
Thanks!
Nexus
Canada
2019 Mustang
I don't know about the 15+, but pre 15 if the battery was dead/removed and the windows were fully up you would be able to open the doors, but not close them again.
The trick was to keep the door open when disconnecting the battery. This keeps the window in the short drop state, and allows you to open and close the door without it being in the sealed state.
Airborne5.0
Ontario
Great point, I will do this. Thanks!
Sigma6
AZ
Jay
11’ GT500, 17’ 350
Over inflate tires and hook up a battery tender, you’ll be fine. That’s what I do.
