DougS550
- May 18, 2020
- Fishers, Indiana
- Doug
- 2019 GT Premium A10 PP1 Whipple Stage 2
Just wanted some thoughts.
- Install FI Interchiller heat phenolic spacers which of course will raise the blower, which means I will have to modify/extend Whipple's 10 rib top mount leg which goes to the whipples front lower mount bolt.
- Whipple 10 rib kit
- I will also be installing MFP crank support
- I will install Whipple alternator relocation kit which requires the removal of the front sway bar which I do not want to do. So I will buy a new PP1 sway bar and mount to a flush surface (don't know what I will use yet) Then remove the sway bar and put on car, Cutting the sway bar on both ends measuring the gap space necessary to achieve the spacing necessary for the install. Weld the spacer pieces on both sides of the sway bar, then have my welder go from their. I am not worried about the flexing being as OEM for it will be proportional from side to side where the extended pieced are welded. (BUT: If I can find a place to retemper the bar I will).
- ATI 20% over crank balancer pulley
- 3.875 Griptec Blower pulley (16ish lbs boost)
- I (possibly) will install an electric water pump which would free up around 8-10hp. Still decided on this one. One comes with idler pulley and the other does not.
- I plan to Install a set of front two piece rotors
- I plan to install a set of steeda front Knuckles and hub kit.
