GregO
FlyHalf, What brand do you use ?Ow40 is what i use in the winter.
5w50 is what i use in the summer.
10w is 10w - the presence or not of friction modifiers is utterly irrelevant. If you can't grok that then read a book on the subject.More 10W-xx Wet Clutch oil spec. gibberish.
LFlyHalf, What brand do you use ?
I have no interest in getting into a viscosity or manufacturing ability by country debate, I just thought it is important to note that bearing clearance is generally a % of the base circle radius of the crankshaft main/rod journal. Directly comparing the clearance differences between a full size V8 and a 750cc bike engine is very much apples to oranges.exactly. bearing clearance-smearance. The spec is 0.025 - 0.050". The coyote is not remotely tight clearance unless your frame of reference is the hand-hewed crap from the 60's or the pieces of shit Ford made in the 80s and identified them as "engines". The Civic type R has 1/3rd the clearance. You Detroit worshipers seem to not understand your technology and precision SUCKS ASS and is a flaming JOKE! If a Japanese designed an engine with such giant slop in it like Americans', there'd be a trail of disembroiled bodies all along the highway. American car technology is the laughing stock of the world and always has been.
The 1970's CB750 had max clearance less than the Coyote min. And it's minimum was 1/3 of the Coyote and the spec oil is 10w. "Designed for 5w" - my god man, do you get paid to shill for Ford? Your ignorance of engineering norms is astounding.
yeah oddly the doc I was looking at indeed mislabled it. I found another with mm, so that does make more sense.. I am assuming when you saw 0.025 - 0.050, you didn't realize that was in millimeters, not inches.
This is the exact reason why I absolutely despise the metric system when it comes to machining. The metric system has its benefits, but old habits die hard and with 98% of the machining in the US still being based off the inch, it's just easier to keep it that way.yeah oddly the doc I was looking at indeed mislabled it. I found another with mm, so that does make more sense.
In any event above -5C whether you start with 5 or 10w it doesn't matter.
The oil is thickest when cold, so if the clearances are good for 5w cold rating anything in the warm rating will flow fine.How did Ford manage to have the same engine that can run both?
I think we will see more of the 0w40/0w50 stuff becoming more common with performance cars, if the EPA doesn't try to strangle it anymore. Traditionally, engine oil with a very low base oil weight (0-5 weight) with a wide spread between its cold and warm nominal viscosity values were typically unstable. But I am assuming they have figured out how to cover that issue with it being more prevalent and seeming to work great.Unrelated to the Coyote and “W”rating. GM has moved the Corvette into 0W-40 street, track and geographical location, doesn’t matter.
or everybody's lying about the "new" increased rate of wear and forcing "early" retirement of an engine that could have lasted far longer.Traditionally, engine oil with a very low base oil weight (0-5 weight) with a wide spread between its cold and warm nominal viscosity values were typically unstable. But I am assuming they have figured out how to cover that issue with it being more prevalent and seeming to work great.
Yea this is really what I was referring to. Admittedly I haven't done much research on the specifics, it was just a rule of thumb I've seen from a long time ago. Oil has come a long way, and low weight base oils with wide nominal weight spreads must be working good since F1 allegedly uses 0w-70.or everybody's lying about the "new" increased rate of wear and forcing "early" retirement of an engine that could have lasted far longer.
actually the improvement in coiled polymer strands' strength has no doubt been real and why they can pull off 0w40 etc. Since the oil is separate from trans, there are far less teeth trying to chop them up.
That said Motorcraft 5w50 is known to "quickly" degrade to 40 after limited use because the polymers break down. Maybe that's not true anymore but it's an old wive's tale from the 90's when they were using sub-standard filaments.
