Ingot2015
Ok. Pin 30 does have 12 volts. Pin 85 has 12 volts with ign on. Pin 86 has 0 volts with engine off and has 2.5 volts with engine on.. And im not getting any volts out of pin 87 with car on or off. 87 might be the problem eh?[FONT="]Check the relay socket with a test light, pin 30 should have 12v all the time.
Check the relay socket, the 2 green wires from the IMRC connector in pins 85 & 86, one will have 12v with ignition on, the other will have ground when the engine is running and be open, no ground when engine is off. Pin 87 feeds power to the inter cooler pump and triggers the dual fan relay
[/FONT]
