gqneon
- Jun 25, 2015
- Westfield, IN
- 18 GT PP / Manual
So I'm running my stage 2 Whipple kit now for about a month and 1200 miles. The other day I smelled a whiff of coolant and being a really proactive person I went home and got to sniffing around under the hood. I found where the 3 hoses come together near the upper neck I had a leak at the joining T and resolved it by tightening a clamp. I then worked through all the other connections and made sure I hadn't had anything shift or loosen up with heat cycling or vibration.
But in checking the belt, I noticed it seemed like it was showing a lot of wear on the non-ribbed side and that the idler pulleys all have a sticky soft rubber build up on them from the belt. This is the Gates RPM belt that Whipple sent with the kit, and I have my tensioner set correctly so it has plenty of working range with this belt.
And it got me thinking some more - I noticed a few times recently that after WOT and coming off the gas I would get a belt chirp for a split second. It didn't do this at first.
So this is my pair o' hypothesis...es....
1. Under hood temps got so high idling that the heat negatively impacted the belt life causing it to wear/melt.
2. The leak at the T-fitting could have been spritzing a bit of engine coolant out onto the belt near that idler and coating the belt unbeknownst to me while driving.
My (self) argument to #1 is that if it were THAT damn hot, it would impact other hoses, fittings, plastic, etc - which it doesn't seem to do.
My unknown on #2 is "will coolant deteriorate a belt prematurely?"
I think #2 is the most likely culprit - and it's my own fault - my BEST GUESS without your input is that coolant got on the belt and when the belt was stressed (WOT) it started slipping and transferring off to the idler pulleys.
What do you guys think? This belt looks like it could have 40k miles on it in my opinion, although it's only got 1200.
I ordered a new belt (and a 3.625 pulley - because traction's overrated anyway) from Whipple and contacted Michael there to see what he thought about the belt, too and sent him these pics. He mentioned that the pulley looks discolored which is indicative of high heat - but it might just be the light since it was iPhone + direct sunlight.
Thoughts?
Thoughts?
