Whipple issue... Helppppp lol
Ingot2015
CT
Ron
2015 gt
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
Wait what? What ground do you add?
Step 119 and 120. Step 120 talks about making the bolt hand tight but never goes back to it in the instructions to tighten it (although I'm looking through the whole instruction book again right now). I remembered this during my install and tightened it. I honestly have no idea if that will help your problem. I'm trying to think of anything.
Ingot2015
CT
Ron
2015 gt
Oh. Yea that wire is tight. An dont think it would have anything to do with it anyway..
Ingot2015
CT
Ron
2015 gt
Oh. Haha. Ok so where would i check that?
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Okay, pin 87 should be open (disconnected) to ground when engine stopped and closed (connected) to ground when engine running.
Whatever is supposed to be pulling 87 to ground when engine is running is not working. Check wire connectivity from relay to plug.
Ingot2015
CT
Ron
2015 gt
I used to be getting 12v out of pin 85. Now im only getting 5. Wtf. Im getting aggravated.:mad:
Ingot2015
CT
Ron
2015 gt
Nevermind. I blew the fuse for it.:doh: i give up
db252
Equinsu Ocha
Bay Area, CA
No giving up! Disconnect everything that harness connects to and start again. I don't have fans so I have no advice on that part.
Ingot2015
CT
Ron
2015 gt
Yea this pin is not grounding.. Everything else seems to check out. It seems like there is an issue in the whipple wire harness to me. I dont know where else to look.
Ingot2015
CT
Ron
2015 gt
I mean what else could it be? My grounds are good. The imrc is doing what its suppose to. Tried a different relay.. The only thing left is the wiring.
db252
Equinsu Ocha
Bay Area, CA
But you said it works when you jump the relay, right? Wire harness works if that's the case. Your tune installed ok as well?
Ingot2015
CT
Ron
2015 gt
I bypassed everything when i jumpered it though. Didnt even have the relay in. An my tune is fine so far. Still emailing logs back and forth. Im lund tuned.
Ingot2015
CT
Ron
2015 gt
I dunno. Im thoroughly aggravated.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Check the wiring continuity.
