Whipple issue... Helppppp lol
zaquhree
Orlando
2015 S550 GT
Brb going to drive my car while you work
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
Ingot2015
CT
Ron
2015 gt
[MENTION=13288]Whipple SC[/MENTION] you ever come across this issue?
v8ter
Typing...
EL PASO , TX
And my fans dont go on either , but the intercooler pump does
Ingot2015
CT
Ron
2015 gt
Oh no its contagious!! Lol
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
I had this same problem initially, the fans nor pump would run, so I called whipple and they told me to try the other connection. Did that and still nothing so I put it back on the first connection and come to find out I didn't press the two connections together hard enough, it finally snapped together tight and worked like a champion. Just something else to try.
Ingot2015
CT
Ron
2015 gt
Thanks. Something else to add to the try list when i get home. Lol
Ingot2015
CT
Ron
2015 gt
Will the pump and fans run with just the ignition on or does the engine need to be running?
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
They won't come on till the PCM sees 200 RPM.
As mentioned make sure not only the connector "clicks" in place with a good squeeze but the pins inside the connector are lined up and engaging eachother.
As far as power make sure the relay is getting power from the fuse box as the connection behind the blower is just a signal wire to trip the relay on and off.
Ingot2015
CT
Ron
2015 gt
Thanks jamie. Headed out to the garage now..
zaquhree
Orlando
2015 S550 GT
You can grab a voltmeter too to make sure they're gettin voltage
Ingot2015
CT
Ron
2015 gt
Still no luck. Have power to the fuses. plug is making contact in the imrc...... Wtf. over.
Whipple SC
Fresno
[FONT=&quot]Check the relay socket with a test light, pin 30 should have 12v all the time.
Check the relay socket, the 2 green wires from the IMRC connector in pins 85 & 86, one will have 12v with ignition on, the other will have ground when the engine is running and be open, no ground when engine is off. Pin 87 feeds power to the inter cooler pump and triggers the dual fan relay
[/FONT]
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
1. Ok maybe check the plug connector to the IC pump mine was hard to seat and needed a lot of pressure.
2. Move up to the red power wire check with test light or volt meter to see if it's getting power when motor is running
3. Check the fuse in the harnes make sure it's seated.
4. Check the ground on the shock tower again make sure it's making contact.
5. Check the power wire going to the fuse block make sure it's connected and tight.
6. you could also test the relay maybe it's not switching power to the pump and fan.
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
I'm totally out of ideas.....I hope the two posts above fix it or at least find the problem. Please update.
