Whipple smooth pulley wobble, concern?
Bbarfoot14
RI
2015 Mustang GT PP
I’ve been noticing 2 of my smooth pulleys on my whipple kit seem a bit wobbly. I tried my best to show it on the video but I’ve played with the belt and it’s def not a belt placement issue. When standing above you can see the lateral movement in the pulley.
Is this something I should be concerned with? Whipple says they are supposed to have some play in them but his seems excessive. Retorqued them to the 30lbs they recommend and that didn’t help.
ugstang17
unknown
none
Jump the belt at the tensioner so the idlers are free and see if you have lateral lost motion there. Had you been wise you could have asked Whipple HOW MUCH LATERAL MOTION IS ACCEPTABLE? When they gave you the spec you could have then setup a dial indicator and measure the lateral lost motion to see if it is acceptable or not.
I have a philosophy I use as a Electromechanical maintenance tech. If it ain't broke don't fix it. If Whipple said some movement is normal and did not give a specification and the unit is not throwing belts don't fret it.
Bbarfoot14
Bbarfoot14
RI
2015 Mustang GT PP
Thanks man I did try that earlier, im able to move it laterally with relative easy but as you said if it’s not broke.
They sent me a new pulley so I’ll put that in place and see if it changes at all.
rtg
CT
Rob
2018 GT PP1+
FWIW, I have seen the same type of movement on the 2018 setup. I am guessing that the lateral movement contributes to some premature belt wear but as ugstang17 said if it's not throwing the belt probably OK. I just keep an eye on it and if I visually detect a change will address it then.
Rob
96gt4.6
Kansas
2017 GT Premium/A6, 2020 Explorer ST
I have the same movement on mine, so far over 1500 miles of abuse and track time with no issues.
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
Wobble is totally normal. When they don't wobble as much, like when they are cold, you get the annoying Whipple belt squeak/ chirp as the belt rubs on them instead of them wobbling slightly.
