Which oil catch can?
s550mustang
Melbourne
Ford Mustang GT MY17
Ford Performance catch can for me. Fit and finish is great and it does the job.
SlowJunk
Kentucky
2018 Mustang GT 6MT
I have the JLT and have had no issues with it. Seems to do the job, fitment is nice, and it is easy to empty.
SVTchris
Port Washington, WI
1993 SVT Mustang Cobra, 2004 SVT F-150 Lightning, 2019 Mustang Bullitt
The Ford needs a tool, loosen/tighten (3?) bolts, and some method to pull the oil out from the top (plunger or towel to soak up). Admittedly, not the most labor-intensive or worst thing in the world, but overly complicated for what it needs to be.
The Ford Performance separator uses quick disconnects on all connections as the picture above your post shows. It is very easy to empty with these quick disconnects.
Below is a link the installation directions. Go to step 7 and it will describe how to maintain the separator. The top screws are only taken out when cleaning the screen is necessary,
https://www.cjponyparts.com/pub/media/images/install-pdf/install_m6766a50a.pdf
18usc371
Naples, FL
Jim
GT350 - Track Package - G0628
Fair enough- I stand corrected - thanks.
Grimreaper
Dallas
2017 GT
UPR here. Remote mount seems to be pivotal to get the most blow by out of the air before it makes it to the manifold.
Build quality is top notch and so are the hoses supplied.
JJR512
Glen Burnie, MD, USA
Justin
2015 Ford Mustang 50 Years LE #1523
UPR. The JLT doesn’t suck up as much. Could if you put some steel wool on the bottom. BBK no experience nor know anyone as guys I’m around chose UPR. Ford isn’t user friendly. You basically have to take a syringe to empty.
Currently at CJPP, the JLT is $50 cheaper than the UPR. And I see on Amazon there are packages of various grades of steel wool for a few to several dollars. I the UPR really ~$45 better than a JLT and some steel wool?
barron64
Auburn, AL
2018 Mustang GT convertible PP1, 6sp, 2006 Toyota Tundra Dbl Cab 4x4, 2009 Acura MDX, 2007 Toyota FJ Cruiser
I bought a generic black aluminum one off Amazon and plumbed it in myself. Used oem pcv hose & fittings with some spare hose to connect it up. Spent maybe $35.
Sigma6
AZ
Jay
11’ GT500, 17’ 350
Check your PMs @JJR512
Torinate
Ontario
2016 GT Convertible
Any fear of the steel wool
Getting sucked up somehow into the intake?
