What PSI
Mitt
Republic of Texas
2014 FJ Cruiser; 2022 MT GT/CS DMG
What is a good PSI to run for daily/spirited driving? Just got a set of 19x9.5 and 19x10 that came with 255s and 275s.
Mitt
Mitt
Republic of Texas
Thanks, Discount Tire set them to 37 for some reason.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
What ever pressure keeps the tread flat across the whole tire
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec, ESS G3X
I run 32 for daily road use, drop to 30 cold when wanting more grip, or will be driving "spirited"..
Keeffa
australia
keith
ford mustang 2018 gt
I had been running at 36 psi, when I got some new rubber they set them to 40 psi and showed me how they can wear unevenly. 32 is to low. I found 40 on the front, where the weight is and 36 on the rear workers well. If you're on a race track that will be different, need to drop the pressure a bit.
Adam the Lighting Guy
West Palm Beach, FL
Adam
2021 GT Convertable , California Special & 2020 Ecoboost Premium Coupe
I generally do 38 on front (the GT) and 35 in the rear. The EB coupe, 35 psi all round.
dirtwarrior
kentucky
Joe
2015 3.7 mustang
I find 35 gives me most traction and better wear
Keeffa
australia
keith
It's also likely that whatever pressure gauge your using, it'll be reading at least 2 psi more than the actual pressure.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
OP didnt say what tires.
generally 32 is good, and they’ll increase pressure on their own as they heat up if you’re actually driving hard. MP4S need to be kept under 38 hot or they fall off. 30 or something is too low IMHO, but it all depends a bit on the tire you’re running.
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
I generally run between 32-34 cold (34 in winter, 32 summer). There’s a few factors at play, including use case (tire, outside temps, tire, etc). That handy little sticker in the driver side door jamb is a good place to start. The cars that come with summer only, lower profile tires from factory (Mach 1 HP, GT350, GT500) would be a good reference point if you’re running those kinds of tires (I don’t recall if factory recommends 32 on those cars as well, someone with that sticker in their door jamb can confirm).
I find in summer that starting at 32 cold will get to 34 pretty regularly with normal driving, 35 on the highway. That’s just about perfect for me and what I run (Conti ECS). I have zero uneven wear and grip feels great on spirited runs.
Will defer to the folks that track their cars on what works for them on track, I haven’t run my car on track.
Mitt
Mitt
Republic of Texas
For now Pirelli P Zeros
Eyesac
Reno NV
Isaac
2020 Mustang GT PP
I typically run around at 31psi. It seems like every tire I've run wants about 30-32psi to have all the tread on the ground. Big traction difference in the rear between 30psi and say 34psi.
K4fxd
NKY
Each tire is different. The Eagle F1's like 35
