psi
JCN
Indiana
Jim
20 Mustang GT, 23 F150
I found 28 gets me a full width contact patch. Jim
MLO 351
Australia
Pete
2021 Mach 1
29 psi cold, usually sits at 31-32 psi when tyres warmed up.
m3incorp
Georgia/Colorado
James
Depends on which tires I have on. The summer tires are at 32 psi. The drag radials are a bit less unless I am driving longer distances; in that case, I air them up to 32 psi.
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
My Nitto G2 are 40 and the Pirelli's are 32.
m3incorp
Georgia/Colorado
James
You don't get spinning on those G2's? Maybe the A10 limit the spinning but on the M6 the G2's were a no go. I had to run the rii drag radials to limit the spinning.
glockholiday
Wild Wild West
Jeff
2019 Mustang GT Premium
Daily driver here, 38psi front and 36psi rear (cold). They wear flat and even that way. 32psi like the door jamb says wears the inside and outside edges which is a sign of underinflated/overloaded tire. Every vehicle I own if I run the door jamb pressure does the same thing so I average 5-10psi higher depending on the vehicle and get flat even wear all the way across the tire.
PC_GUARD
Fl
Scott
2016 Mustang GT PP1
Depending on vehicle I run around 36. I have Indy 500's on my car, and the pressure moves a lot, hot/cold at least according to the dash gauges.
glockholiday
Wild Wild West
Jeff
Yes my 38 and 36 cold will be 42 and 40 in the hot AZ sun driving around town all day
Matthewstorm
NC
Matthew
Just to confirm these are the NT555. Haven't made them spin yet.
m3incorp
Georgia/Colorado
James
Correct the NT555 G2 is a performance summer tire (many on here don't see them as a performance tire.) and the NT555 rii is a drag radial tire. I never tried the NT555G2 on the rear.
sirben711
Missouri
Ben
2021 Mustang Ecoboost 10R80 w/ FP Tune
I do 33 for the fronts and 32 in the rear when cold.
I like the extra turn in I feel with the extra psi. I feel it helps rotate the front end just a little more.
pt's21
NOWHERE
The door sticker says 32 COLD. Now, please define COLD?
I usually run 3- 5 over sticker. I find it a good compromise between best wear (5 - 8 over) and best comfort (sticker).
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
34 lbs cold on street tires.
CVCashmere
