What else to install while doing springs and sway bars?
CorvZ061
Georgia
2022 GT
I recently spent my ford pass points on the FRPP street springs and sway bar kit. The car they will be going on is a 2022 GT Premium (non-PP). I wont actually be doing the install for a bit, but curious as to what else would be a good idea to do while I'm in there. I've been looking at Steeda's IRS bushing support system too.
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
It depends on what you're going to do with your car but since you're changing springs might as well upgrade the struts and shocks while you're right there.
CorvZ061
Georgia
2022 GT
It's not going to be raced. The goal is a fun daily that also gets driven to the mountains for some fun driving time. No drag racing or anything like that, so I don't feel like a stop the hop kit would be needed. I also don't think anything too stiff would be needed. I'm good with firm, which these springs are going to be on the softer side of things to work with the stock struts.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Agreed with doing the front endlinks.
Really though, shocks are where its at.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
The stock shocks don't work with the stock springs. Add the Ford track shocks or Bilstein B6's.
The stop the hop kit plants the IRS. If you feel the rear of the car wobbling this fixes it.
CorvZ061
Georgia
2022 GT
And the irs bushing supports won’t help with that?
K4fxd
NKY
They are part of the stop the hop kit. Those bushing inserts and the IRS braces will make 90% of the improvement.
If I were to do just one it would be the braces.
GrabberBargeCaptain
CA
PP control arms are a nice upgrade. Strut tower brace and cowl extension. Toe link bearings. Also please change the shocks if you're doing springs. Ford Racing dampers are an amazing upgrade even for daily driving.
CorvZ061
Georgia
2022 GT
I already have the strut tower brace and cowl extension. I’ll look into the toe link bearings.
As it sits now, my list has added Koni STR.T strut/shock (I’ve run Koni in the past and had good luck), Steeda end links, IRS alignment and busing supports.
WD Pro
United Kingdom
Lime GT
That’s a good idea :like:
That’s a great idea :like:
They will, massively :like:
Yes, they defo compliment each other :like:
This is the only bit my opinion varies on.
Personally I think they do a very similar job, and the first one that’s done will give you the biggest % gain :
I am a PP1 mag ride car, but the biggest single difference I have noticed to date is the subframe lockouts.
I know some people rave about the rear subframe braces but to me, the subframe lockouts made a much bigger difference.
I suspect it comes down to which mod goes on the car first.
First mod (be it braces or lockouts) gets you 90% of the total benefit, second mod gets you the last 10% i.e. whichever you do first, will leave the biggest impression on you.
Lockouts are smaller and lighter, but more difficult to fit.
Braces are easier and quicker to fit.
Both mods are 100% reversible.
Both will corrode if used in a harsh environment without additional maintenance / protection.
WD :like:
As the braces are easier to fit and the OP already has someone going in and messing with the subframe, I would take that opportunity to get the support bushes done - Doing the braces at a later date is a easier and quicker DIY option, that won’t mess with any alignment settings that should have been done following the spring install (the same can’t be said or guaranteed swapping the order of those two mods around).
I would add that the subframe alignment dowels should be done at the same time. They are inexpensive and will ensure the subframe goes back on square, with future repeatability. Again and like the bushes, this area is getting disturbed so it’s almost like getting them fitted for free.
Don’t expect any performance improvements from them, it’s purely a convenience mod, even though some say otherwise - that’s just the placebo effect working in overdrive …
I was kind of in a similar situation to the OP (Ford had to drop the subframe for a warranty repair), and I used that as an excuse for them to do the following mods at the same time, with minimal additional work / maximum saving when compared to doing the mods separately at a later date :
  • Subframe bushing supports.
  • Alignment dowels.
  • Diff bushing supports / diff bolt sleeves / upgraded diff bolts.
  • H pipe.
WD :like:
GrayMater22
Sanford, FL
James
22 Mustang GT Premium
I have done steeda minimum drop springs, pro-action shocks/dampers, strut tower brace, 2 point g-trac, but as others have mentioned the irs brace and alignment made the biggest difference in stabilizing the rear end giving you that planted feeling.
CorvZ061
Georgia
2022 GT
  • Alignment dowels.
  • H pipe.
WD :like:
I’ll be doing the install myself and taking it somewhere for an alignment, which is why I’ll be doing the subframe alignment and bushing kit. I can add the braces later on if need be.
K4fxd
NKY
The braces act like subframe connectors in the old cars. So you get a better front to rear connection along with controlling the rear. Reason I would pick them over the bushing idolators. In reality I would and did use both.
