Anything else I should install while doing new springs/shocks?
2015Etrac
PA
Black 2016 Mustang GT Premium 401a
Is there anything else I should consider installing while I'm doing this? Something that will be easy to add while in the process of doing the springs/shocks? I have a BMR Cradle Lockout which will be added during the install. I was thinking about new sway bars to replace the stock GT ones, but now sure if I really need them.
2015Etrac
2015Etrac
PA
Brakes?
List exact spring n shocks n consider PM BMR?
I'd like to add Brembo PP brakes up front but that's not in my budget right now. I'm using GT350R springs and Koni Sport shocks.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Camber plates!
West TX GT
Ian
2018 Royal Crimson GT
Might as well do the diff lockout while you are lowering the cradle for the cradle lockout. It will save you from doing the same work later and BMR's new poly kit is down right cheap at 60 bucks.
Bluemustang
2015 Mustang Base GT
Maybe want to consider a LCA bearing upgrade and Ford Racing toe to knuckle bearing. That should really solidify your rear suspension. In my experience it's added to the "handle like on rails" feeling.
West TX GT
Ian
I agree with this. In my opinon it is the best thing I have done to my car. I didn't suggest it because it is no trivial install (but very doable). I installed the toe links, LCA bearings and diff lockout at the and time I did the springs and dampers. It was like getting a new and much better car.
2015Etrac
2015Etrac
PA
Thank's for the replies. Should I worry about the stock GT sway bars?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
IMO, no, although you may want a PP rear to take a small bit of understeer out. The springs you've selected take a ton of roll out of the car.
2015Etrac
2015Etrac
PA
Thanks. Good to know. I really don't have the money to be spending on anything that's not necessary.
Burkey
Australia
The diff inserts form Steeda (fro example) require dropping of the subframe. Plenty of other really good bits don't eg. LCA bearings etc.
If you don't like doing things twice, church te diff inserts in while you have the subframe lowered. CB005 also, obviously.
I did the springs first and then added all the rest of the bits. It's ok to do it that way, but double dipping.
PamAndJim
DFW
2015 EcoBoost Mustang
FWIW, when I did my spring install, I also added Steeda subframe braces (which you have covered with the cradle lock out), Steeda IRS Subframe Bushing Support System, and the Steeda Subframe Alignment kit (they make one specifically for the BMR lockout). The other little parts required almost no extra labor to install.
Jon|3.7
Houston, Tx
15' 3.7 Mustang
hey i have all those except steeda braces, and i have the steeda sway bars, could you tell me the function for those braces?
PamAndJim
DFW
