Way to accidentally enable launch control?
ronnyek42
United States
Mustang GT pp2, 2023 Bronco Wildtrak, Ram 3500
Earlier today I noticed with clutch pushed in my 2018 wouldn't rev past 3k rpms or something.
I noticed the lc icon on the dash and going into track mode then track apps and launch control it's enabled.
Being this is the second time this has happened, I'm wondering if there is some short cut to turn it on... Cause it seems too hard to accidentally do without a shortcut of some form
KingKona
Virginia
Shlomo
2019 GT
It happens to my car occasionally too.
No idea of how it happens. I just shut it off.
I Bleed Ford Blue
North East OHIO
Launch control doesn't kick in if you ease into the throttle. If you mash the throttle it will only go to the setpoint until you release the clutch pedal. If you ease into it, you can go all the way to redline if you want
Oakley
Lee
2022 Mustang
wait so to use launch control you just push the clutch in and hammer the throttle to the floor quickly?
I Bleed Ford Blue
North East OHIO
exactly. of course you have to go into track apps and turn it on first and it has to be warmed up. Basically once you get the LC on the cluster it's ready to.
BTW the launch control will stay on once you turn it on, so next time you start the car it will be on. The default setting is where you leave it.
KingKona
Virginia
Shlomo
2019 GT
exactly. of course you have to go into track apps and turn it on first....
Please pay closer attention. That's not what either of us are experiencing and explaining.
Sometimes it just turns on by itself. It's happened to me many times.
I Bleed Ford Blue
North East OHIO
I understand that, I was just trying to explain how it works so if you find yourself in that situation with the LC lit up on the cluster, you can avoid it being activated.
I know you have, but has the OP gone into the track apps and turned it off?
KingKona
Virginia
Shlomo
2019 GT
I still don't think you understand.
It turns itself on. I (and presumably the OP) know how to turn it off, but then it will just turn itself right back on. A few dozen times I've had it turn itself on. No input from me. Just look down and there's an LC on the dashboard.
The discussion isn't about activating it once it's on, it's about stopping it from turning itself on.
At least that's what I'm talking about, and what I believe the OP is talking about.
I Bleed Ford Blue
North East OHIO
I get that. Until you can figure out why it does it, at least now you know how to not activate it.
Off the top of my head, I would say it has to be a programming glitch. You and OP are the only two I've ever heard of that has this issue.
Linkster1666
AZ
Link
2019 Mustang GT Premium Orange Fury PP1 A10 401A 3:55
So the ONLY thing with this car that 'Stays On' is Launch Control?
But every other setting, you have to go through a 15 step menu hunt to turn On or Off?
I must now go play with Launch Control.
I Bleed Ford Blue
North East OHIO
You don't have launch control, it's only on manual cars.
KingKona
Virginia
Shlomo
2019 GT
O.k.....gotcha.
Yeah, I don't know. At least once a month I look down, and the LC light is on.
Linkster1666
AZ
Link
