Water filter
jabberwoki
puyallup
steve
69 428 CJ Mach 1 , 2020 gt350
Anybody recommend s reasonably priced water filter for washing your car?
jabberwoki
jabberwoki
puyallup
steve
Thanks Mate , i`ll pick up a pack tomorrow. First wash and wax this weekend.
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
NO problem, it works really well and circumvents having to install a messy water filtration system... Auto Fanatic has some really good ideas.. he's a bit on the edgy side with that NY accent, but his content is great and he really appreciates the lineage/history of Ford.
Nfs1000f
Upstate NY
Neal
2017 GT350 & 2019 Ford Fusion SEL Hybrid
This is the route I went with. Not as perfect as going with a complete filtration system but much better than untreated water.
Lorne34
Project Hidalgo
Wisconsin
Lorne
2019 GT350
Hey Neal, thanks for the second on that... no offense on the NY accent :wink:
Point45
SoCal
josh
19 gt350, 05 tacoma, 10 Ducati 1098SF
I put one together using a couple whole house filters, BUT I just found out the local car detailing supply shop sells RO filtered water and its about $20 to fill a 55 gallon drum.
Edit: A 55 gallon drum takes up alot of space and you will need a decent pressure washer to use it.
This is what I went with, one filter for sediment and one filter is a mix bed resin filter, throw in a couple plumbing fittings/QD hose connections and youre done for about $200.
The sediment filter is just to get more life out of the resin filter and slow the flow rate some to make it more efficient.
https://www.amazon.com/Geekpure-Fil...words=20-inch+Big+Blue&qid=1611344583&sr=8-46
If you want to get fancy you can plumb in a dissolved solids meter to tell you when to change filters but from experience its not needed as you will notice a drop off in performance before it becomes an issue. I only use the water from the filter for filling the buckets and rinse.
The mix bed resin filter is the largest cost, when I first started using this it was $90 for 2, 20in filters, . That price has almost doubled, next time i need to replace a filter it will be with a refillable cartridge.
How much water you can filter will depend on the quality of the water you have. For me washing 2 cars and a truck once a month it will last about 6 uses before I notice small spots that a quick once over with a detail spray will remove.
If you have good water quality or only wash one car then you can probably just use the mix bed resin filter by itself, and/or go with the smaller 10in filter housings and spend about 1/3 the price.
