jc1804
- Sep 3, 2014
- SE MI Downriver
- 2015 EB PP 50th Race red
Well I did an experiment, real simple real cheap. you most likely have everything you need laying around. 2 washers & 2 lock washers. I found a couple washers that are the same size as the OEM locknut OD that fit properly to the viking thread, installed the shock put the washer in locked it down then put the lock washer in & used the jam nut to lock it all down. It's only a small sampling of travel, but I put about 20 miles on & the ride is back & no more noise (so far)
I'll post if it changes
