Very bad wheel hop
2LoudMut
America
2015 Mustang GT 50 year anniversary
Hello everyone, I have a 2015 mustang gt 6 speed. I noticed if I aggressively accelerate or just dump the clutch in 1st and launch the car it gets severe wheel hop, I’m aware a little wheel hop might be normal for the s550s but even my buddy who has a track pack 2015 says he’s never seen wheel hop like that. I’m assuming it’s maybe bushings that went bad? I’m not too sure hopefully someone here has had a similar issue. Thanks
JayAction
Dallas
Justin
2021 GT500
Wheel hop is pretty standard from the platform even when new.
It's possible some bushings might be deteriorating, but you know steeda makes a 'stop the hop kit' that most people swear by. BMR has something similar
I'm actually about to install 'stop the hop kit', along with the upgraded delrin vertical links, and the toe links from steeda.
Steeda sell replacement bushings that are a lot firmer as well. Might want to look at those if you are dead set in replacing them or notice they have deteriorated. I hear the firmer ones, cause an increase an NVH though.
daSNAK3
Cary, IL
Jake
2021 GT
Stop the hop kit
2LoudMut
America
I actually just purchased the Steeda rear subframe brace,
Hopefully it helps
WItoTX
Houston
Kyle
'17 GT350
Hopefully it helps
It won't. I have everything, plus spherical RCLA bearings, still doesn't help, at least not on super grippy concrete. Jus the nature of the geometry of the rear of these cars.
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
Check differential bushings. Jack the rear of the car up and have someone shift it from first to reverse and back with the car running. You should be able to see the diff slop back and forth if the bushings are bad. Might even see them ripped.
With a 2015 it’s likely the bushings are wearing down or ripping
tj@steeda
Timothy
Hopefully it helps
Shoot me an email to [email protected] & I will put you in touch with our team with some possible items to check out & then some of the recommended Stop the Hop Kit components.
Happy to help & consultations are free :)
Best Regards,
TJ
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Then you have other issues. After the stop the hop kit mine spins or hooks, no bunny rabbits at all.
WItoTX
Houston
Kyle
'17 GT350
Glad your experience is better. Maybe we are not using it in the same application. It's not just me with the issue, as many other forum members have posted the same issue. It helps, but it's not the solution.
Adam the Lighting Guy
West Palm Beach, FL
Adam
2021 GT Convertable , California Special & 2020 Ecoboost Premium Coupe
I'm suprised no one mentioned the rear shocks. At 9 years old, compression dampening may be weak and contribute to the issue as well.
K4fxd
NKY
Wheel hop is caused by deflection in the rear suspension. You have something moving when it shouldn't.
If you can place a go pro and point it at every suspension joint in the rear. Eventually you will find it.
I use my car on both drag strips and road courses. The car is set for road course, drags are secondary.
tj@steeda
Timothy
^^ this - but that is what our team will want to check on from tire pressure, the tires you are running, etc.
TeeLew
So Cal
Tim
For sure this is true, but it's a common problem.
