USB charging port
rwp50
New Lenox,il
Bob
2017 Black California Special
Seem to have lost the ability to charge the iPhone using USB port either in the console or above the console.
Ford said you’d have to remove the console to replace whatever controls the ports.
Any suggestions or similar experiences?
RWP
KingKona
Virginia
Shlomo
2019 GT
It's more likely to be your phone, or your charging cable, than the car.
Have you checked those?
You do understand those charging ports only work when the car is running, right?
lacanteen
Louisiana: Cajun Country
George
My last phone needed to be unlocked in order to charge thru the USB port.
KingKona
Virginia
Shlomo
2019 GT
Yep.......could be the settings on the phone itself.
OP, how old are you?
First Stang
2023 Mustang Mach1
Check the phone’s charging slot. Sometimes a piece of lint will prevent a phone from charging. Also, agree on the usb cable as a possible culprit.
rwp50
rwp50
New Lenox,il
Bob
Phone charges everywhere else. But I’ll check the cords anyway.
thanks!
rwp50
rwp50
New Lenox,il
Bob
We’ll I’m 73 and still fly helicopters but open to anything I’m not familiar with.
A ‘17 California Special and when having the rear camera recall accomplished the technician tried with his Apple cord and didn’t work for him either. Said I’d have to bring it back in.
So I’ll check what all of you have suggested.
Truly appreciate everyone’s responses!
Thanks,
RWP
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
Try checking the fuse too (not sure which one it is, would have to check the manual). Seems odd that both ports would fail at the same time so it might be something as simple as the fuse going out
KingKona
Virginia
Shlomo
2019 GT
.....when having the rear camera recall accomplished the technician tried with his Apple cord and didn’t work for him either.
Did this start before the recall work, or after?
His cord didn't work with whose phone? His or yours?
Torched10
Atlanta
Bob
The only thing common network 3 ports is fuse.if it didn't work with techs cord it can't be cord.its fuses 53 and 54 20amp fuses.you can look at them and see if they're bad.you can also just swicth the 20 Amp with another to verify which one us bad
I've got extra fuses which I always do with cars.just a suggestion.
KingKona
Virginia
Shlomo
2019 GT
There's other reasons the tech's cord wouldn't work;
-It could be the wrong cord.
-The OP's phone settings could be set wrong.
-Even the tech may not know the car needs to be running. Many other cars will keep charging when the car is fully off.
Torched10
Atlanta
Bob
Here's Link to check fuses.hope it helps
junits15
MA
Justin
2019 Mustang GT
Hold down the skip forward arrow and the power button until sync resets, the system is honestly very unreliable and sometimes requires a full hard reset to get working again. It can and does shut off charging to the ports if there is a software error.
If it still doesn't work, and you've verified that the phone and the cable are good then its likely the USB hub inside the center console. They do fail.
Fords Sync system is kind of bad if I'm honest, I've had issues on multiple Fords with it.
KingKona
Virginia
Shlomo
2019 GT
Hold down the skip forward arrow and the power button until sync resets.......
Does that do a hard re-set where updates need to be done again?
illadvised
San Diego
Brian Spilner
2015 GT - 6R80 - Paxton 2200SL
No that is basically the same as leaving the battery unplugged for a while. A master reset will delete all saved data in the radio, like bluetooth connections; but a master reset doesn't seem to solve many problems at all for the sync system. I am not sure if there is a way to do a hard reset where you have to redo the updates
