Upgrading Tire Size....thoughts
Golgo69
Golgo69
Herb
2019 BULLITT
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Have 19" on my ride. Eventually I wanna go with 18"x12" rear 18"x10" fronts w/ more sidewall. Ideally I'd prefer 17"X12" rear & 17"x10" fronts but the picking are slim for those.
Golgo69
Golgo69
Herb
2019 BULLITT
I love that original BULLITT look!
I'm looking at the TOYO Proxes R888R, 265/30zr 19 (they only offer the 275 in a 35zr) and 305/30zr 19
fighting to keep that original look! That 30 will give me a lower profile right?
shogun32
Northern VA
at the south pole don't you need tracks and spiked tires? Though I guess the donuts are epic until you fall into a cravass. :)
the days of wide tires for 17 or even 18 is long gone. It's 19 or 20 now. If you want sidewall you're limited to slicks and drag radials.
shogun32
Northern VA
TOYO Proxes R888R
blech no.
265/30 will be 'rubber band'. I would choose 265/40.
look, spend a few hours looking at the 'spec' tabs on tirerack.com
shogun32
Northern VA
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Nah.. apex has a good selection of wheels in the sizes I need. I can get Nitto NT 555 G2 in a 315/40R18. Close enough I guess.
Mr. Met
06 Time Person ofthe Year
NYC
JJ
2020 GTPP Premium, 2015 GT Premium, 1999 Expedition EB
blech no.
I was also going to mention using tire rack to check specs, even if you are not buying from them. You will note on there that these numbers are standardized and do not necessarily give the exact measurements of the tire. Two tires that are the "same" size can vary, even from the same manufacture. For instance, when I went from the PS4S to the AS/3+, a 265 was closer to the 255 PS4S specs then 255 AS/3+.
Bikeman315
Myrtle Beach, SC
Ira
It's gonna be these.
what are your recommendations for front and rear with the rims at this size?
  • Front 20x10 ET +35mm / 34 lbs.
  • Rear 20x11 ET +50mm / 35.4 lbs.
i was thinking
285/35
305/35
Honestly I really like the choices Steeda made for their Bullitt.
275/35-20 front and 315/35-20 rear.
