Tremec 3160 swap?
theflyinggear
Lancaster CA
Conor
2018 GT Mustang
Hey anyone swap a tremec from a Mach 1 or Bullit into a regular GT with a MT82? Would it be easy or is there weird things that need to be done for it to work. I have a 2018 GT and I am strongly considering the swap after having felt how good they feel.
boB
boB
2019 GT PP1
One thing to look for is if your car has the gear select sensor (mounted on the transmission). I thought this started on 2019 with rev-match but another post noted that the 2018 MT82 also has the sensor in which case it could be very difficult to change transmissions.
theflyinggear
theflyinggear
Lancaster CA
Conor
2018 GT Mustang
Yeah I don't have the auto rev match in mine.
theflyinggear
theflyinggear
Lancaster CA
Conor
2018 GT Mustang
theflyinggear
theflyinggear
Lancaster CA
Conor
2018 GT Mustang
What you really want is a Magnum XL swap. Should run about $6-7k in parts, probably another 2k to have it all installed by a reputable shop.
https://www.jpcracing.com/jpc-2018-2021-mustang-gt-tremec-magnum-xl-complete-conversion-kit/
That is a bit over kill. I do not need a trans built to hold that much power. Some of the 3160 I have seen on sale were like $2500-$3500. Which would be much more reasonable price wise. Some 3160 I find new are even cheaper but meant for different cars.
General Geoff
Allentown PA
Geoffrey
2018 Mustang GT PP1
If you think you'll save a bunch of money on a 3160 swap over the Magnum XL, go right ahead
Brazos609
2015 GT Premium PP Recaro
ShadesOfBloo
SE Virginia
1980 Datsun 210 wagon, 1992 Nissan 240SX, 2008 Evo, 2020 Mustang GT
The GT350 TR3160 setup is a direct bolt in on a GT, not anything like any other Tremec swap.
(Knowing this is a bit of an old thread...)
You don't have to swap out a crossmember or transmission mounts?
Do the MT82 and TR3160 have all the same plugs for electronic doohickeys?
Brazos609
There is a GT350 cross member and mount and I think it is a little softer, based on the feel in hand, than the GT, probably to absorb more vibration. I think some people who have swapped reused their GT cross member and mount.
larsif
Centennial, CO
Larry
2019 Mustang GT PP1 Oxford White
Interested in this swap. Specifically the 2021 Mach 1 trans as it has rev match and is a Tremec trans. Assume it is the 3160. Anyone know the part number for the Mach 1 trans?
NGOT8R
Adrian
2019 Bullitt
Would the 3160 swap also require a different PCM or would the existing just need to be tuned for it?
Brazos609
Multiple people have swapped the GT350 TR3160 into 15-18 GTs and you should adjust the gear ratios in the tune so the car knows what to expect when it compares RPMs to wheel speed.
boB
boB
2019 GT PP1
But do we even know the 3160 is stronger / more durable / shifts easier / etc. than the MT-82D4? Some versions of the 3160 have low specs for torque capacity (although these also have a high numerical 1st gear which can weaken a transmission).
