55R2014
I came across this on the TREMEC website about the 3160 in the GT350.
526-HORSEPOWER FORD SHELBY GT350 MUSTANG EXCEEDS 100 HORSEPOWER PER LITER WITH NEW 5.2-LITER FLAT-PLANE V8
Ford Media LinkAbout the TREMEC TR-3160 6-Speed Manual Transmission
The TR-3160 six-speed transmission was designed to be used in light truck, SUV, and performance applications. It can be configured as either single or double overdrive. Centerline distance (the distance between the input shaft and the countershaft) is 81mm. This dimension is what typically drives torque capacity, hence its relevance here. A higher number means greater strength potential with respect to torque load as larger diameter gears can be used. Each gear (and shaft) is of SAE 4120H steel. All gears are hard finished with laser welded clutch teeth.
The aluminum cased TR-3160 weighs 112lbs (dry, with "mass reduction") and is an end-load design. Externally, the unit consists of an integral clutch housing, main case, and tailshaft housing. The multiple shift rail system allows for both direct mount or semi-remote shifters. The detent notches, springs, and bullets, have been designed to allow the best feel possible in terms of shift quality. Coupled with low friction linear shift rail bearings, the unit provides exceptionally smooth gear shifting.
Hightlights
Double and triple cone synchronizers feature hybrid as well as sintered bronze friction material. They are the same size as used in the TREMEC TR-6060 transmission. The greater the friction surface, the easier the transmission is to shift.
First and second gear synchros are triple cone while the remaining gears (including reverse) are double cone. The cone rings use what is referred to as a hybrid arrangement since one side uses a carbon friction material and the other side uses sintered bronze.
The TR-3160 also features a "reverse inhibiting solenoid" system that prevents shifting into reverse if the vehicle is moving forward at 3 mph or higher.
