flyboygsxr
Any car with big rubber up front will tramline. The problem gets even worse if you have a bunch of negative camber.
Section width of the PSS that the 350 wears actually has a 10.0" contact patch up front, 10.7" in the rear. The R's Cup 2's have an 11.0" contact patch up front and an 11.7" out back. These are from tire racks exact measurements, which is interesting!YOu're going to get some tramlining unless you go with some shoddy all season tire and you're still going to get a bit here and there. Perks of having a tire that's 11.6" wide up front.
Ahh yes, I got the designation mixed up. The measurements I quoted however are for the actual width that contacts the road. I found it interesting that for tires are only supposed to be "10 mm" wider from 350 to R, the contact patch actually increases by a full inch (25.4mm).the tread width is 10 and 10.7 the sec. width is 11.9 and 12.3 for the GT350 MPSS
I believe you are right. I am interested to see the difference between the new PS4 and the PSS.Ahh yes, I got the designation mixed up. The measurements I quoted however are for the actual width that contacts the road. I found it interesting that for tires are only supposed to be "10 mm" wider from 350 to R, the contact patch actually increases by a full inch (25.4mm).
Apparently the 350's PSS tires are tuned to deliver better wet performance and daily drive ability similar to AMG's PSS spec tires, whereas others like Porsche and the Corvettes for example actually use a more aggressive and sticker compound that's also wider.
The 285 section rear PSS ZP tires on my fathers Stingray actually have a tread width of 11.2", making them actually slightly wider than the 305 Cup 2's on the front of my R!
For sure, I'm eager to read the comparison as well. I imagine it'll be an incremental change and nothing drastic in terms of feel or ultimate performance, but they were already leading the pack with the PSS anyhow.I believe you are right. I am interested to see the difference between the new PS4 and the PSS.
Yeah some of the differences in widths are very interesting. Just helps reveal what the priority was when the OEM requested a specific tire developed for XYZ carSo check this out! Below is the same size PSS made for three cars. SL is what the 350 wears. These are the tread width listed as measured on a 10.5" rim. Interesting how there is such a difference in tread width.
295/35ZR19
(100Y) SL 10"
(104Y) XL MO Mercedes 10.3"
(104Y) XL Star BMW 11.1"
Now I am curious as to what the psi used for each car when measured or if there is an actual wider tread with no load?
Yeah, weird ;)Weird, I haven't noticed a significant decrease in tramlining after I put the G trac brace on. I've learned to live with it. Keeps me more engaged with the road.
