Timing bouncing at idle and black tailpipe
CrackedHorn
Kansas
09 Mustang GT/CS; 15 Mustang GT
Couple of quick questions while I'm sitting here at this event I was dragged to. lol
Is this timing bounce normal and will the Ngauge let me view fuel trims per bank or detect a weak injector or cam phaser? Why would 1 tail pipe have more soot than the other ?
1) I notice my spark adv is jumping from 23.5 - 26 at idle. Is this normal on a coyote?
2) Bear with me here: I noticed recently at idle and at low revs my car sounds...different. Almost like a lope you would hear from a cammed
pushrod engine. (6th gear at 55mph i can hear this)The sound is mild and my wife doesn't hear a difference but I also noticed the idle is just a tad off and will skip a beat every 10-30 seconds at idle. Once the engine is above idle it runs very smooth except for the 3k rpm "burp" that has always been there when accelerating.
My passenger side tail pipe definitely has considerably more soot than the driver side. More condensation at idle on that side as well based on my finger swipe. No lost oil that I've noticed.
I put my scan tool on the car and no codes or misfires were detected. Cats are at same temp (about 880 degrees), and no red flags popped up.
Something just sounds a tad...off and I'm curious how the passenger side tail pipe could have significantly more soot than the driver side.
Gen 2 GT, Ngauge, muffler delete, Lund tune, 18 mani.
Torinate
Ontario
2016 GT Convertible
Does yours “pop” at idle?
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
The coyote, at least stock, uses ign timing for idle speed control. It should vary a lot like -5 to 20 depending on circumstances.
Was that burp there before you had it tuned?
CrackedHorn
Kansas
Nothing i would call a 'pop'. Just a stumble or miss every do often
It will crackle on decel and sometimes pop
CrackedHorn
Kansas
Thank you for the info.
I cannot remember for sure if that burp at 3k was always there but I believe it was
CrackedHorn
Kansas
Can anyone comment as to why the passenger side tailpipe would have significantly more soot compared to the driver side?
K4fxd
NKY
What exhaust do you have? X, H true dual?
You may have a cat starting to go away or a leaky valve seal. Hard to say.
drive_55_not
S,East
2014 Coyote, S197 3v, 2018 Gen3 [RIP], 2020 Challenger 'Cat
Log it and see if bank 1 running rich.
I'd start by pulling plugs and see what they look like
CrackedHorn
Kansas
Factory exhaust with a muffler delete.
Cats will be removed this winter when I install the cat delete. If I have a valve stem seal going I guess I have an excuse to get a port and polish. :idea:... I'm a glass-half-full kind of person.
K4fxd
NKY
If you have a tuning device log it like was said above. If not ForScan is free and a dongle is about 50
