Miss at Idle
Wsvi
Rock Hill South Carolina
Ed
2019 Mustang GT
Have a 19 gt a10 that all of a sudden developed a miss at idle ,under load it runs fine, the car just turned 18k but before it goes to the dealer was trying to see if there was a simple solution.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Any codes? Is it tuned?.. before you take it to the dealership check your plugs..
ORRadtech
Atlanta, Georgia
Describe what you mean by a miss. A small skip or a significant dip in idle rpm?
Dominant1
Dr Frankenstang
Check this video, good info:
Wsvi
Wsvi
Ed
2019 Mustang GT
you can audibly hear it in the exhaust and feel it in the car, almost like a pop in the exhaust.
Elp_jc
None
Hey Dominant1, could you show oil pressure at the time of the dips? We know it's the intake (BorgWarner) phasers, but what's exactly defective? And could it be oil pressure differences? I noticed oil pressure is quite low at idle on my car. That's probably why Gen3s are prone to the infamous 'tick' because of that. My car doesn't have either issue yet with 3K miles on M1 0/30 oil; hope it stays that way. Wondering what exactly is the issue with the oiling on the intake phasers. Thank you for posting that video.
Dominant1
Dr Frankenstang
I have a gen2 coyote so i don't have the problem. I think the guy in the video said that what solved his problem is switching over to 5/50 synthetic motor oil. That viscosity is what I’ve always used.. the brand i use is “Driven”, which is specifically designed for coyote engines.
Wsvi
Wsvi
Ed
2019 Mustang GT
check engine light finally came on ,p0301 going to the dealer to let them handle it.
brianbr
Surprise
Brian
2019 Magnetic GT PP
I just took my 19 mt82 to the dealership for the 6th time for rough idle, misfire (p0300 and p0316) and oil pressure light coming on. Started at 3,800 miles now has 7800, I am beyond frustrated with ford.
Dominant1
Dr Frankenstang
Yeah that’s cylinder 1 misfire, they’ll fix that with a crank relearn if that cylinder isn't down on compression.
Dominant1
Dr Frankenstang
With multiple misfires and an oil pressure light coming on, you may be in for a long haul with a new motor from Ford..keep us posted..
