this guy says hes on his 3rd 18 engine
kidamer
ohio
2018 mustang gt 10 sp auto
seems we just need to throw these cars off the side of a cliff, or are the dealers just replacing them to replace them to charge ford for the warranty work? hmmm
Fatguy
Toronto
2017 V6 Mustang
Yes I have seen two in a row but three would be a first. Frankly I’m staying away from this engine (and staying with my V6 because all the new 17s sold out fast) because I just don’t trust that spray on liner process in truly mass produced engines (though there are other problems with the engine). I’m a Mustang guy but even I will send guys to the Camaro SS until Ford sorts this out.
SlaughterOfTheSoul
Actual Engineer
Cen FL
2018 Mustang gt pp1
It's really easy to diagnose. Bore scoping is a simple process. It's also easy for Ford to ask for proof, so I doubt it's the dealer pulling one over. I doubt Ford has a fix because they haven't even acknowledged the issue.
ihc95
2018 GTPP A10 401A
I've seen this guys videos. He has the same idle tick that everyone has but he's convinced it's a major issue. Why do you think the second engine did it as well? All 2018+ 5.0s have the unsteady idle tick. His 3rd engine will do it too.
Nothing to see here imo.
usgiorgi
Fairfax, va
C6 Z06
Because not everyone has it and he's right that it's something to do with loose tolerances. If you pay that much money for a new car, it shouldn't sound like a clunker. If every 5.0 sounded like this, then it'd be one thing. The fact that not everyone has the tick shows that there's some variable that hasn't been identified. Could be harmless or could be catastrophic. Just saying it's normal isn't gonna help anyone.
ihc95
2018 GTPP A10 401A
I think you're confusing the 2300 RPM death rattle with this idle tick. The rattle is definitely a problem, the tick is probably not. Do you even own a 2018 GT? Most people are saying they have the idle tick.
usgiorgi
Fairfax, va
C6 Z06
my 2016 had the bbq tick which sounded identical. I brought it in for service and the service advisor who met me at the drive in garage said they definitely heard it. Then the tech who started working on it could not reproduce it. I asked if I could do it for them and they told me that the car was already at the body shop. A month later and 4 bad warranty repaints later, I traded it in.
The tick came after the 1st oil change and was most noticeable when idling and when using very light throttle.
growler
Indiana
2018 mustang gt pp
why do you think the rattle or the tick is an issue? what other DI four cam engine are you guys basing this on? TO THIS DAY no one has been smoking or dropped a piston because it rattles, and ticks no one even seems to be using excessive oil...mines been rattling loudly on and off since I noticed it a 500 miles,i have 4 k on latest oil change and i'm down 1/2 quart with about 12 passes at dragstrip on the change, i'm getting 18 mpg on e-85 and I drive 90 miles a day at 80 mph to work..ford tries to tell people its not a problem and people don't believe them even though their cars have no issues.. what the hell is wrong with you people? You don't have anything to compare it to!!!The rattle and tick is an annoying BUT NORMAL trait with this engine. trust me if your ring tolerances are off it will smoke and use oil, lose mileage and power ,no need to buy a scope and please send in the video of it because I want to see it.
usgiorgi
Fairfax, va
C6 Z06
1) My 2016 was not a DI engine, hopefully you know that. It had the same ticking sound and I'd argue that the DI isn't the cause since not every 2018 Mustang has it.
2) I had a Mazdaspeed3 which was DI and although you could hear the HPFP, it never sounded like any of these videos.
Why do I think it's a problem? Because a metallic clunk/tick isn't a normal sound for a healthy engine.
growler
Indiana
2018 mustang gt pp
how do u KNOW its not normal,how do you know its not harmonics from the fuel pump, theres zero evidence its not normal and tons of evidence it is and the 18's tick as well
usgiorgi
Fairfax, va
C6 Z06
Each engine replacement costs Ford about 10k. Each buyback costs them the same. They're not just gonna approve new short/long blocks and buybacks if they didn't think there was a problem here. This is Ford. They're a very cheap company when it comes to warranties.
There have also been a few people to blow their engines and one person who has this tick who had metal shavings in his engine. You can say it's all a coincidence but I guess only time will tell. If you're ok with your engine ticking and clunking, that's on you. Me and many others think it's a serious problem. Sounds of metal on metal contact aren't good in an engine. Do you really need a source on that?
ponyv6
ozzy
2019 301A PP1 Velocity Blue
we do not know. Thats why we give it to professionals. Everybody wants their car to last long with a health engine. I agree to the fact that ford wouldn't spend even $1 unless it is really necessary. the brand doesn't really matter, no dealer would replace anything unless it is necessary.
My car is at the dealer too. It has been a week and finally mechanics were able to check my car on saturday. I got a call and they stated that, they heard it and waiting for a reply from FORD. I guess they didn't think that it is normal.
growler
Indiana
2018 mustang gt pp
Ford buys back cars because of dissatisfaction as well, cheaper for them to take a 2 grand hit and be done with it,.... i'm saying the cars are fine, the dragstrip time slips are proof ,my oil consumption is proof, wheres the video guys proof that its not normal, has he dynoed it or ran it at drags and its slowing down? is he using excessive oil? are the mechanics doing leakdown tests or just guessing, like the one post where a tech replaced the valve train and didn't fix it ?the engine is new to them as well.. I have seen one single picture with some discoloration on a cylinder wall that was too high up to be piston slap and nothing else,but guys not liking the noise, I don't like the noise,but there's nothing wrong with the engine. I do agree that ford needs to provide everyone some info and that's the only thing that's screwy about the whole deal.I read these threads just to see If ford has made an announcement but none ever comes
bootlegger
Enginerd
Mount Pleasant, SC
James
Ex 2008 Mustang GT Owner
There have been 2 guys with piston scuffing, 2 guys with full engine failures (one dropped a valve), at least 2-3 guys with high oil consumption, and about 50% of 2018 owners reporting a rattle from 2k-3k rpm. We don't know if it is or isn't an issue at this time. Ignoring it certainly isn't a great solution. If you have the rattle, it is best to at least take it in and have it reported to Ford. With enough complaints, they will be pushed into putting out an official statement or TSB. Right now, some dealers are saying it is normal and others are very concerned. No consistency, so I doubt Ford has communicated much.
FYI, if there is a fuel system issue in a specific load/speed situation, you will never see that in your drag strip times. When you floor it, the system is using full pressure and passing it through the direct injectors. There is a possibility that the HP pump is working up to full pressure around 2k rpm, yet fluid isn't being passed through quickly to the direct injectors yet under partial load. This can cause cavitation inside the pump.
Angry50
Jacksonville, FL
Fred
2017 Shelby GT350
can i report my 18 and all local 18s to me are functioning fine? maybe my area got all the good ones.
