Thinking about a built shortblock
Stymee
Delray Beach, Fl.
Joel
2019 Mustang GT
Van Voris is running 16psi
According to his record setting pass
Cars legit but it ain’t no street car
aleccesarenriquez
San Antonio, TX
Alec
2017 GT PP
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Stock engine traps 162 on 16psi. Got it.
nobgob
Nob
2016 GT
I know, right?
Someone help me with this math. I always thought you double the manifold pressure you roughly double the horsepower? So a stock coyote at 460 hp is about 920 hp on 14.7 psi of boost. So 16 psi would be somewhere around 960 hp at the crank right? So then that would be something like 815 rwhp (going through a th400). So if all that is reasonably accurate, then just 815 rwhp is putting a 3,800 lb car through the traps at 8.2x and 160+ mph? Is my math wrong? I'm just not used to seeing 3,800 lb cars e.t. and mph like that on only 815 rwhp. Seems like it should take a lot more power to do that?
Anyways, if the stock motor is capable of this then there's no reason to go built. Unless it's just a unicorn living on borrowed time.
Stymee
Delray Beach, Fl.
Joel
2019 Mustang GT
I know, right? If the stock motor is capable of this then there's no reason to go built. Unless it's a unicorn living on borrowed time.
He has a very smart build, but if u took 10 stock engines it would be interesting to see if they would survive 50 runs and repeated street miles
50 runs isn’t exactly a whole lot, I had 100’s of runs on a mid 10 SEC stock NA build with no failures (LS) and mid 10’s are no where near the STRESS an 8.20 ET puts on a short block
By the way he 8.22 was on 17-18 psi
nobgob
Nob
2016 GT
Thanks for the correction. I'll re-do my math...
So a stock coyote at 460 hp is about 920 hp on 14.7 psi of boost. So 18 psi would be somewhere around 1,020 hp at the crank right? So then that would be something like 870 rwhp (going through a th400). So if all that is reasonably accurate, then just 870 rwhp is putting a 3,800 lb car through the traps at 8.22 and 162 mph? I'm just not used to seeing 3,800 lb cars e.t. and mph like that on only 870 rwhp. Seems like it should take a lot more power to do that.
Stymee
Delray Beach, Fl.
Joel
2019 Mustang GT
Bet even through an efficient converter it’s a 25 % loss
So 870RW is very close to 1100
You could also look at his fueling to figure out HP
David Van Voris from his you tube video’s seems like a very nice guy, I would just ask him
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Car is making over 1k whp. Guaranteed.
nobgob
Nob
2016 GT
David Van Voris from him you tube video’s seems like a very nice guy, I would just ask him
I was figuring 1,020 hp at the crank with 15% loss through the trans (typical for a th400).
If the drivetrain loss was even higher, as you say 25%, then the rwhp would be even lower... (1020 x 0.75) = 765 rwhp.
To be at 1,100 rwhp would require 1,300 at the crank with a typical 15% loss through the trans.
I agree with 80FoxCoupe that car has to be making well over 1K at the wheels. Which seems unlikely on only 18 psi and a completely stock motor. Yes, it's a truly bad-ass car.... and yes debatable whether it's a street car anymore (has no overdrive that I'm aware of). Anyways, replicating this performance with a stock motor seems nigh impossible and I can't imagine that engine is long for this world.
gimmie11s
SoCal
Murica!
Absolutely 100% over 1000.
I saw 18.xx+ psi on the gauge in one of his videos a few months back.. im sure he's running higher boost now.
18 psi is nearing 1100 wheel..
I made 913 on 12-13 psi.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Either way guys. It's fast!
OP, get u a built engine and send it.
Drsmith33
Cincinnati
Donald
2018 Mustang gt
Making very well over 1000whp. I’m right at 900whp with 16psi on my gen 5 Whipple and trapping nowhere near 162 in the quarter. As far as everyone on here saying that a gen3 coyote motor is a ticking time bomb at that power.... you can’t say that when the guy has made multiple 8 second passes and even more 9 second passes with 0 issues. Could the motor go at any point? Yes. Many people blew their motor on stock power and stock tune. That doesn’t justify anything. I myself have made many passes at the power level I’m at and I drive the car very very hard on the street when I see an opening. Calling someone stupid because they didn’t build their motor with their power level is stupid in itself. You have no idea what the motor is capable of and David Von Voris can attest to that. These cars love boost. Good fuel (e85) and a good tuner (Lund) will make these motors last.
aleccesarenriquez
San Antonio, TX
Alec
2017 GT PP
I was using wheel numbers earlier btw
Like 80fox said, definitely over 1k
I would say at 18 psi he’s pretty much for sure over 1100 actually
Stymee
Delray Beach, Fl.
Joel
2019 Mustang GT
Making very well about 1kwhp. I’m right at 900whp with 16psi on my gen 5 Whipple and trapping nowhere near 162 in the quarter. As far as everyone on here saying that a gen3 coyote motor is a ticking time bomb at that power.... you can’t say that when the guy has made multiple 8 second passes and even more 9 second passes with 0 issues. Could the motor go at any point? Yes. Many people blew their motor on stock power and stock tune. That doesn’t justify anything. I myself have made many passes at the power level I’m at and I drive the car very very hard on the street when I see an opening. Calling someone stupid because they didn’t build their motor with their power level is stupid in itself. You have no idea what the motor is capable of and David Von Voris can attest to that. These cars love boost. Good fuel (e85) and a good tuner (Lund) will make these motors last.
Making very well over 1whp. I’m right at 900whp with 16psi on my gen 5 Whipple and trapping nowhere near 162 in the quarter. As far as everyone on here saying that a gen3 coyote motor is a ticking time bomb at that power.... you can’t say that when the guy has made multiple 8 second passes and even more 9 second passes with 0 issues. Could the motor go at any point? Yes. Many people blew their motor on stock power and stock tune. That doesn’t justify anything. I myself have made many passes at the power level I’m at and I drive the car very very hard on the street when I see an opening. Calling someone stupid because they didn’t build their motor with their power level is stupid in itself. You have no idea what the motor is capable of and David Von Voris can attest to that. These cars love boost. Good fuel (e85) and a good tuner (Lund) will make these motors last.
Yep
