The "what things weigh thread."
Status
Not open for further replies.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
Stock airbox & soundtube with filter, clamps, hardware 8lbs 11oz.
Less Weight
East Coast
I weighed everything together and got 43lbs on my scale including all the rear belts, brackets and bolts and all. LMR delete carpet is right at 2lbs so loss of 41lbs. Replacing both heavy premium seats with 13lb racing seats which will save 100lbs. Between the two 140lbs lost which is significant.
Thanks a bunch for the info, boss; It was just what I was looking for. :)
By chance, have you installed that LMR rear seat delete? If so, what are your thoughts of it? Worth the price?
F1scamp
Upstate Ny
16 Mustang GT
Anybody know the weight of the p/s non power v6 cloth seat? Been scouring the junkyards for one, but would be interested to know the actual weight difference.
Terminator2
Spring Hill Florida
David
2016 Mustang GT Premium
It's pretty nice and fits well I do wish they had something better than the Velcro to hold parts of it on. I ended up putting a few screws through it to help secure it.
Terminator2
Spring Hill Florida
David
The premium leather heated cooled airbag seats are actually only 55lbs each not 65lbs or so as reported!!! I weighed them both last night and both drivers and passengers are exactly the same 55lbs. Makes me doubt reports of the cloth manual seats being 50lbs each. Those are probably only 35lbs or so each in reality because the heated cooled and power motors are definitely more than 5lbs total.
Terminator2
Spring Hill Florida
David
OEM front bumper support 13lbs
OEM plastic front bumper support part 2lbs
OEM fog lights (pair) 1.5lbs
OEM front Radar assembly 2.5lbs
I’ll have more this weekend.
Terminator2
Spring Hill Florida
David
OEM rear bumper support 16.5lbs
OEM rear plastic bumper support 4lbs
OEM carpet side panels from trunk 5lbs
BluFlash5x8
SW U.S.
1987 5.0 LX, 2012 GT500, 13' GT500, 13 & 14 5.0...
Making a list here. Will have more parts soon - just needed to start keeping track!
OEM PP Shock Tower Brace: 7.6lbs
OEM PP K-Brace: 10.4lbs
OEM Front Subframe (K-Member): 58.2lbs
BMR Street/Handling K-Member:
BMR Drag K-Member:
Watson Racing Drag K-Member & Arms: 42lbs
OEM Rear IRS Subframe (Empty): 55lbs
OEM IRON Diff Housing, Loaded - No Fluid: 99lbs
OEM IRON Diff Housing, Bare/Empty:
OEM Aluminum Diff Housing, Loaded - No Fluid: 77lbs
OEM Aluminum Diff Housing, Bare/Empty: 16.64lbs
OEM IRS Halfshafts: 21.1lbs/each
FRPP Halfshafts: 31lbs/each
GForce Halfshafts: 31lbs/each
OEM Iron Diff Loaded, Halfshafts, Inner/Outer Stubs - NO Fluid: 158.5lbs
G-Force 9" Diff Loaded, Halfshafts, Inner/Outer Stubs - NO Fluid: 163.2lbs (4.7lbs gain to do a 9" GForce Swap)
OEM Rear Lower Control Arm: 15.24lbs - each
OEM Rear Upper Camber Link Arm: 4.65lbs - each
BMR Billet UCL: 2.22lbs each
Steeda Adjustable UCL:
OEM Vertical Link: 3.2lbs - pair
BMR Billet Vertical Link: 3.2lbs - pair
OEM Rear Toe Link/Rod Arm: 2.42lbs - each
BMR Adjustable Toe Rod w/ Lock Out Plate:
OEM Rear IRS Cradle Mount Bushings: 1.05lbs - each
BMR Delrin Cradle Mount Bushings: .50lbs - each
OEM Rear IRS Diff Mount Bushings: .90lbs - each
BMR Billet Aluminum Diff Bushings: 1.47lbs - each
OEM Rear Lower Control Arm Bushings: 1.1lbs - each
BMR RLCA Bearing Upgrade Bushings:
OEM EPAS Rack: 36.46lbs
OEM Motor Mounts: 7.8lbs - pair
BMR Adjustable Motor Mounts: 3.8lbs - pair
OEM Windshield Washer Fluid Res. w/ Fluid: 9lbs
OEM Battery: 31.31lbs
Deka ETX18: 17.67lbs
Anti-Gravity YTX12-24: 5lbs
Anti-Gravity YTX12-20: 4.5lbs
Anti-Gravity YTX12-16: 4lbs
OEM Catback Exhaust: 72lbs
Magnaflow 3" Comp CB: 44lbs
Corsa 3" Sport CB: 61lbs
Bassani X-Pipe CB: 38.4lbs
OEM Axle Back Exhaust: 38.4lbs
Pypes Touring Axle Back: 20.4lbs
OEM "Mid Pipes" w/ Cats: 22lbs
MAK O/R Pipes:
OEM Resonator "Suitcase": 17lbs (others report 22-23lbs)
CJPP H-Pipe Res. Delete: 10.5lbs
SR Performance X Pipe Res. Delete: 9lbs
OEM GT/V8 Passenger Side Header: 10lbs.
OEM GT/V8 Driver's Side: 19lbs
Borla GT/V8 Longtube Headers: 14.2lbs per side
OEM Base 18" GT Wheel w/ Tire: 54.5lbs
OEM PP Model 19" GT Wheel w/ Tire: F-60.6lbs / R-64.3lbs
OEM Dark Stainless Painted Aluminum 19" x 8.5" Wheel w/ Tire:
57.6 lbs
OEM Foundry Wheel w/ Stock Tire: 55.2lbs
OEM Foundry 20" Wheel w/ Tire: 64lbs
OEM Premium
20x9 Foundry Wheel: 35.7 lbs
OEM GT PP Front 9" Wheel: 32.5lbs
OEM GT PP Rear 9.5" Wheel: 32.4lbs
Billet Specialties 17x4.5 w/ MT SR 28" Radial: 39.8lbs
Racestar 17x4.5 w/ MT SR 26" Radial: 34.6lbs
Billet Specialties 17x9.5 w/ MT 28" Drag Radial: 51lbs
Billet Specialties 17x10 w/ Hoosier 28x10-17 Slick: 42.9lbs
Weld RTS 17x10 and Nitto 555 285/40/17: 50.4lbs
MRR M350 19x10 Wheel: 23.7lbs
HRE FF15 Wheels: Each
18x10 ET40 - 21lbs
19x10 ET40 - 22.6lbs
19x11 ET55 - 23lbs
20x10 ET40 - 24.2lbs
20x11 ET55 - 24.6lbs
OEM Lug Nuts: 12oz (per wheel, 5)
Titanium Lug Nuts: 3.5oz (per wheel, 5)
OEM GT Cloth Seat: 50lbs
OEM Cloth Recaro Seat: 50lbs
Corbeau FX1 w/ Bracket: 25.7lbs
OEM GT Base 14" Front Brake Kit (Rotor/Caliper/Pads): 43.8lbs per side (87.6lbs total L+R)
OEM GT PP 15" Front Brake Kit (Rotor/Caliper/Pads): 47.2lbs per side (94.4lbs total L+R)
Aerospace 13" Lightweight Street Brakes (Rotor/Caliper/Pads/Brackets): 19.4lbs per side (38.8lbs total L/R)
OEM GT Base REAR Brake Kit (Rotor/Caliper/Pads): 31lbs per side (62lbs total L+R)
OEM GT PP REAR Brake Kit (Rotor/Caliper/Pads) -
Aerospace DRAG Rear Brake Kit (Rotor/Caliper/Pads/Brackets): 12.2lbs per side (24.4lbs total L+R)
OEM GT 14" Base Front Rotor: 28.56lbs (57.12lbs pair)
OEM GT PP 15" Front Rotor: 33.4lbs (66.8lbs pair)
Aerospace 13" Lightweight Street Rotor: 14.3lbs (28.6lbs pair)
BAER Eradispeed GTPP Slotted 2-Piece: 22.8lbs (45.6lbs pair)
OEM GT Base Rear Rotor: 17.2lbs (34.4lbs pair)
OEM GTPP Rear Rotor:
BAER Eradispeed GT Slotted 2-Piece: 12lbs (24lbs pair)
OEM GT Base Front Caliper: 15.24lbs (30.5lbs pair)
OEM GT PP Front Caliper: 13.8lbs (27.4lbs pair)
Aerospace Lightweight Front Caliper: 5.1lbs (10.2lbs pair)
OEM GT Base REAR Caliper: 13lbs (26lbs pair)
OEM GT PP REAR Caliper:
Aerospace 2 pot DRAG REAR Caliper:
OEM Front "base" Sway Bar: 12.7lbs
OEM Front PPGT Sway Bar: 14.5lbs
FRPP Track Front Sway Bar: 15.5lbs
OEM Rear "base" Sway Bar: 4.4lbs
OEM Rear PPGT Sway Bar: 4.5lbs
OEM GTPP Front Strut:
OEM GT Base Front Strut:
Koni Yellow Front Strut: 10.3lbs each
OEM S550 Front Strut ASSEMBLY - "Complete" (strut, spring, strut mount): 19.40lbs / per side
VikingFront Coilover Kit ASSEMBLY w/ Sway Bar Mounts - Complete w/ BMR CC Plates: 15.90lbs / per side
OEM GTPP Rear Shock: 4.5lbs
OEM GT Base Rear Shock: 4.5lbs
Koni Yellow Rear Shock: 4.9lbs each
OEM Front V8/GT Coil Springs: 4.8lbs - each
BMR Drag Front Springs: 3.95lbs - each
BMR Performance Front Springs: 4.8lbs - each
BMR Min Drop Front Springs: 4.75lbs - each
BMR Handling Front Springs: 4.8lbs - each
OEM Rear V8/GT "base" Coil Springs: 9.7lbs - each
OEM Rear GTPP Coil Springs: 8.5lbs (reported for '17 MY)
BMR Drag Rear Springs:
BMR Performance Rear Springs:
BMR Min Drop Rear Springs:
BMR Handling Rear Springs:
OEM Front Sway Bar End Links: 1.6lbs pair
BMR Adjustable Front End Links: 2.2lbs pair
OEM 2-Piece Driveshaft / Auto: 29lbs
OEM 2-Piece Driveshaft / Manual: 36.2lbs
Shaftmasters Auto 1-Piece Aluminum DS - 19lbs
Shaftmasters MT82 1-Piece Aluminum DS - 18.73lbs
Dynotech MT82 1-Piece Aluminum DS - 17.4lbs
DSS Auto 1-Piece Aluminum DS - 27.6lbs
DSS Auto 1-piece Carbon Fiber DS - 24lbs
OEM Front Spindle/Hub Assembly: 19.3lbs each
OEM Front Spindle - Bare: 12.19lbs each
S197 Front Spindle/Hub Assembly: 16.25lbs each
OEM Front Control Arm: 4.3lbs each
OEM Front Radius Arm: 6.8lbs each
OEM Front Tie Rod: 2lbs each
OEM Tire Air Pump: 5lbs
OEM EVAP Module/Canister
OEM Engine Sound Tube: 1.3lbs
OEM Engine Coil Covers: .75lbs/each
OEM Engine Cover: 3.4lbs
OEM Battery Cover: 1.23lbs
OEM Plastic Trunk Latch Cover: 2.40lbs
OEM Rear Seats: 30.8lbs
OEM Rear Lower Seat Cushion: 11lbs
OEM Trunk Carpet Cover: 4.6 pounds.
OEM Stock Floor Mats: 2.6 pounds.
OEM Carpet / Complete: 16.5lbs
OEM S550 BARE Hood: 31lbs
OEM S550 Loaded Hood: 36~lbs
Trufiber Carbon Fiber (Lightweight) Hoods: 17lbs
Trufiber Carbon Fiber (Standard) Hoods: 30lbs
Trufiber Fiberglass Hoods: 40lbs Anderson Composites CF Hood: 22lbs
2015 Mustang GT Performance Pack 300A - MT82 Transmission
Curb Weight (scaled at BMR) - 3736lbs
Front Unsprung Weight: 143.9lbs per side
Rear Unsprung Weight: 132lbs per side
2015 Mustang GT Base 300A - 6R80 Automatic Transmission
Curb Weight (scaled at BMR) - 3704lbs
***AFTERMARKET "ADD-ON" PARTS (parts that the vehicle is not equipped with from the factory)
Chassis Jacking Rails
BMR CJR001: 21lbs
BMR CJR002: 13.76lbs
Steeda Ultra Lite: 12lbs
I question the fluid level of the cars weighed at the end of the list. The auto sales have alsway been 35-65 lbs more than the stick, since 2002. An drew my base 300a, automatic 5.0 with sync and power driver seat, with full fluids was 3691 lbs.
mattchan6668
Korea
Mustang Gt
Can someone tell me what's the weight between 2015-2017 mustang gt intake manifold and gt350 intake manifold
MakStang
Greece
www.cellentis.uk
Makis
A 2017 miraculous little beast
2.475 lbs - 1" spacer, Coyote Wheel Part # 5450-5450-A14.
Is this for all four spacers? I thing I just added 2.475 lbs on my car :D
thehunterooo
2006 Corvette
The pp car weighs more with the strut tower braves, heavier/bigger pp rims, other bracing, bigger brakes, etc
Status
