The "what things weigh thread."
Status
Not open for further replies.
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
ahh, well then. Yea I wouldn't really know, just referring to the issues BMR had with the stock one. Now is the 9 inch aluminum lighter than the 8.8 iron?
The 9" aluminum pig loaded with gear and diff yes
BMR Tech
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Not true..
Cast Iron GT 3.31 rearend (pumpkin) complete 96.4 lbs. Dry
Cast Iron GT/PP 3.73 Torsen rearend (pumpkin) 105.7 lbs. Dry
Is this factual data?
If so, I will add it to the list! :cheers:
68fbjjz109
Open Road
15' GTPP
The info I have for the Aluminum differential is 76lbs dry.
No LSD. The aluminum housing itself is 15.75-16lbs
I'll count the teeth from the photos later, or ask the dealer to run the vin of the car we got the info from while my GT is in for 10K service and oil change
LIGISTX
Los Angeles
2012 V6 Mustang
Any info on what the stock flywheel weighs? Pretty sure the s197 coyotes where 22 lbs, same for the '15?
Sent from my jailbroke iPhone using Tapatalk
klumpikat
Chick driver
La Jolla, CA
Liz
2015 GT Premium, 2023 Mach 1 Premium
LIGISTX
Los Angeles
2012 V6 Mustang
According to this product description the Ecoboost stock flywheel weighs 30.5lbs.
http://www.lethalperformance.com/fi...-ecoboost-light-weight-aluminum-flywheel.html
Dunno if that helps :shrug:
Unfortunately not really. The v6 dual mass POS is 33lbs, I have heard the coyotes is 22lbs, never heard of the eco's tho. Good info tho.
Basically only reason it matters is I am going to be taking my dads stock GT clutch and flywheel to put in my v6 in order to eliminate the amazingly awful dual mass the v6 has. Pretty sure I will be losing rotational mass, but I just want to see how much. If the v8's is in fact ~22 lbs, I'll take a free ~10 lbs reduction. If not, I'd buy a new flywheel to go with his clutch.
racer24crm
Philadelphia
Chase
2015 Ruby Red GT
anybody know how the stock sway bars compare to the weights of aftermarket ones such as BMR or Steeda?
Ericc B
NL/SP
Various Mustang GTs
I weighed my new KW V3 components. Weights are for single units, left and right are obviously the same:
KW V3 Strut
6,05 kg
KW V3 Rear spring
4,8 kg
KW V3 Rear shock
2,7 kg
The total set weighs exactly 1kg more than the OEM PP components that came off the car.
LIGISTX
Los Angeles
2012 V6 Mustang
Any idea on stock flywheel number?
IvanCRF
El Paso, Texas
5.On'ry
What stock 18" wheels are the lightest? I keep researching and don't see it. Thanks.
18''Foundry Black Painted Aluminum Wheel = 55.6lbs with the stock 235/50/18 Pirelli tire.
Base combo weighs 54.5lbs.
Therefore, the base wheel weighs about 1lb less.
panic
Spain
2015 Mustang GT
Did any of you guys attempted to gutt the doors? I guess there is plenty to dump inside there, starting from the power windows and ancillaries, any pic of the inside?
Status
