Test driving - this normal?
Shadow277
Arizona
2016 Mustang GT 2012 Corolla
Been looking at GT350s and I found one to test drive. Trust me, I really like it. What an improvement over my GT.
Anyways, I had two concerns for the 2017 I drove. Is the clutch supposed to stick to the floor? As in, it doesn't release easily like in the GT, forcing my foot to be on the clutch longer.
The second thing is that it sounds like it's hitting the rev limiter at a little under 8k RPM. It kept throwing me off because I instinctively shifted at 7.8k every time I heard it.
Blwnsmoke
NH
Brian
2018 GT350
Clutch should return when you release, no sticking.
Mine does this too with redline but figured it was the engine hitting it faster then the gauge can keep up. Never researched it or asked
cmxPPL219
Toronto, Canada
Eric
2019 Mustang GT PP2
As others said, clutch pedal should not be sticking to the floor. Something's up with either the clutch pedal or the hydraulic system perhaps (hoses, air in the system etc.) that could be causing the pedal to not return.
Shadow277
Arizona
Awesome, thanks everyone. I'll avoid this one. I'll keep lookong for another GT350.
cmxPPL219
Toronto, Canada
Eric
2019 Mustang GT PP2
Bender
SE PA
17 LB GT350R HR909, 22 AB GT500 CFTP
Clutch is susepct as it should not stick as others have said.
As for the redline, I believe the ECU will limit the RPM to 8000 if the oil temperature is not above 190 degrees. I know Ive ran into this before on cooler spring and fall nights when cruising the oil can be down in the 170s and 180s
Shadow277
Arizona
And add a quart of oil every 500 miles?
Bender
SE PA
Some motors eat oil some dont. I have been lucky with my late 17 build that eats almost no oil but I check it often. Mostly after its filled up. I keep a quart of oil in the trunk if needed.
Shadow277
Arizona
Good to know. Thinking about trading the GT for a GT350 right now. 30k miles at 56k. Affordable yeah but it just feels fiscally irresppnsible since I have a kid now.
matthewr87
2018 GT350
Are you sure you are hitting the rev limiter? The engine cuts out momentarily at the rev limiter. I've done it at VIR a few times by accident.
mavisky
Cumming, GA
Kyle
2018 GT350
I think it's 7800rpm. Don't hammer forged motors when they're cold.
Shadow277
Arizona
I hear revs bouncing like it is hitting the limiter.
mavisky
Cumming, GA
Kyle
2018 GT350
Then you're hitting the oil temperature controlled reduced redline. It's covered in the GT350 owner's supplement and is there to help protect the bearings while the oil is still cold.
