TDStuart Tuning Adventure
tdstuart
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
tdstuart
tdstuart
Arizona
Triston
How did you get OS provider? Mine stops at rear o2 sensor
Mine shows the OS provider. Maybe try updating or reinstalling
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
They all will have the same injector data
K4fxd
NKY
The check for updates button did not work on mine. I had to get the updated version from PCMtec's website.
K4fxd
NKY
Rolls said they will not upload any files that are not a direct read. Somehow they can tell if a file has been read and re-flashed.
junits15
MA
Justin
2019 Mustang GT
following your thread, I'm also learning but have a more stock car than you. I find that PCMtech isn't as intuitive as HPT but after enough time it isn't an issue at all.
I will say that I don't like their logger, I still can't figure out how to show fuel trim percentage, the graphing ability isn't as good and the logs are just more of a pain in general. The software is buggy and cashes a lot, I use HPT for logging still.
Do you plan to do flex fuel?
furdfan2018
AZ
Mustang
Great thread... keep it coming and best of luck!!
tdstuart
tdstuart
Arizona
Triston
I might use the hptuners logger too as I have lots of experience using it but we will see.
And I won’t be doing flex fuel but I will be doing e85/e98. I’ll probably end up making a tune for 91oct, e85, e54, and e98 as they are the common percentages around my area. Might even do a 100octane tune as there is a pump close to me
I am hoping I can use my hptuners RTD device or ngauge to save the tune like it’s a stock tune and have the ability to flash it on the go without a laptop
junits15
MA
Justin
2019 Mustang GT
In my experience that does work, though I've always done "read entire" and "write entire". I'm not sure how it does on the fast read/write
tdstuart
tdstuart
Arizona
Triston
Wish i would have found this before i dropped 140 and waited forever for the obdpro
Well I couldn’t get mine to work haha. You can get another type that is like $30 but pcm tec doesn’t recommend them
Midwestracer
Fayetville Arkansas
chris
2018 mustang gt whipple
ole well it took a couple times but ya just got the one they recommend
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
You could do all this in one tune with the PCMTEC Custom OS with no flashing needed. Flex fuel can take care of the ethanol content changes and then you can have a separate multi-tune slot for 100 octane. Or you could just have a tune slot for each fuel type. Either way, no flashing needed.
tdstuart
tdstuart
Arizona
Triston
Only thing needed is more money to buy the custom os version haha
junits15
MA
Justin
2019 Mustang GT
by the way you aren't likely going to be able to copy lund's timing, when you get into the tune you'll see why. its not straightforward like that
If you want to learn I would seriously consider starting with the Coyote cookbook, it isn't perfect and there are things in there that aren't how I would do it, it isn't instructions for tuning, but it does give you a good overview of how the mapped points system works. Its "close enough" and it will allow you to understand what you're up against. It will help you get a good idea of what this is.
Its $125, you can read it in one sitting, if you take notes you'll get through it in a week. I would recommend you take notes especially if you're new.
