Takeoff Brembo Caliper/Disc condition
Ewheels
SoCal
Eric
'18 GT PP1, '23 F150, '24 4Runner Pro
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
You carefully spread them with a pry bar or screwdriver
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I must be missing something.....
How are you guys changing pads without removing the caliper? You have to compress the pistons since the new pad will be thicker. I've always removed the caliper and used this to compress the pistons
https://www.amazon.com/Lang-Tools-279-5420-Brake-Caliper/dp/B0079GQKDE/ref=sr_1_1?crid=220RWTTGT2O6K&dchild=1&keywords=lang+brake+caliper+press&qid=1603397558&sprefix=lang+brake+,aps,212&sr=8-1
Yeah I just use a couple of small C clamps to pull the front pads back (near where the friction pins go through). Definitely don't fuss with removing the caliper, and I don't have to pry against the friction material. The brembo caliper finish is pretty tough, so doesn't even mark that with the steel C clamps.
Brian@BMVK
Illinois
2015 GT - Sold
Use your fingers on the old pads and compress the pistons with the pad.
K4fxd
NKY
It's a lot easier if you open the bleeder screw.
Open bleeder, put a hose on it make sure you have it vertical for 5 or 6 inches, then loop it down into a catch can.
Take screw driver and wedge it between the rotor and the pad ear next to the pin. You can use a flat plastic trim tool if you are worried about marring your rotor or friction material. After you get it moving the rest is easy. Once the pistons are fully seated, close the bleeder.
This is a bit tricky because you don't want to remove the hose until the bleeder is tight. This prevents air from getting into the caliper. Do the other side, top off master.
Ewheels
SoCal
Eric
I change rotors between street and track set as well. That's why I have to take the calipers off.....forgot that little part :crackup:
