smoke14me
Hex Once again thank you for all of the help I would not have even contemplated this swap if not for all of the information that you and others have shared here.In the ACM
727-01-01 xxXx xxxx xx 0= is the internal amplifier for volume correction
You said you didn't have a SAT antenna, just clarifying you meant SAT (Sirius) if so make sure that:
727-01-01 Xxxx xxxx xx 1= Sirius 9= without Sirius
This fixes issues with phone calls, mic operation, and bluetooth operation.
Just to make sure that you know exactly how I am set up. I have a 2017 base GT Auto 3.15 gears.
I swapped in a Syn3 APIM, ACM and bezel from a 2017 GT350 that had Sattelite Radio and Navigation along with the new USB Cables, HUB, and your harness. I did not install a GPS or Sat radio antenna because I do not like or use either of those two features.
I did also notice another item this morning that I will have to fix also this evening my remote start on my key fob did not work. I changed the line of as built data 7D0-01-02 xx8x xxxx xxxx to identify my car as an auto.
