Switching from 5W-20 to 5W-30. Best Oil?
Fire__GT
Fire__GT
Southern California
Luis
2018 Mustang GT Premium Performance Pack Level 1
For performance applications I generally recommend A3/B4 as the spec to follow, which is a European spec. It has more zddp, higher starting TBN, and higher hths than your typical api SP oil, all of which translate into better engine protection in extreme circumstances. While over-generalized, it can be argued that a typical a3/b4 oil will perform better than ($$) boutique API SP oils.
which exact brand spec do you use for your car?
SheepDog
Colorado
Dax
Iconic Silver 2022 MACH 1 HP
Amsoil SS 0w-40.
GregO
Illinois
S550 GTPP
Fuchs, Pentosin, Liqui Moly, Motul. Just a few of the best from across the pond since the thread took a turn to Euro oils.
My Castrol Edge Professional is no longer a German made product, even smells and looks different. Now made at BP Whiting Indiana. Still rated for 20K OCI (10K is my comfort zone)
I'm holding out that the API will reclassify GTL oils into their own group. I honestly believe GTL's may be the best base stock to date. Royal Dutch Shell is the only GTL game on the planet and Shell owns Pennzoil and Quaker State.
engineermike
La
2018 GTPP A10
I was between that and the M1 0w40 (also Euro oil) recently. M1 got the nod.
Most of the engine's life has been on PUP 5W30.
The M1 0w40 is a good choice and usually available at Walmart for $25/jug. That’s a phenomenal bargain for what you get. I use pennzoil for the gtl base oil. I used pup 5w30 in my old Whipple f-150 before I was comfortable using a euro oil.
TomOz
Canberra, Australia
Tom
Mustang GT 2018 Ruby Red, 5.0 / 10 speed
I run PUP 5W30. Even got the 5W30 oil cap to go with it
Interesting info about the oil cap with 5w30.
Does it fit the 5.0L Gen 3 Coyote?
I haven't seen anywhere that states that the EC-971 is compatible with the Mustang, so wondering if you have installed it yet?
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
Yes that is my pic I took when i purchased it. the 5W30 cap is still in my car. If the cap that came with your engine /car originally looks like the one on the pic, then you can use it.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Of course it fits. In other markets that's the standard cap. It's only in the US where they want you to use 5W20.
Cobrakit
Southern Maryland
Ken
2019 Mustang GT PREMIUM PP1
I just confirmed fit as well. Took one off my wifes ecoboost edge and it worked on the gt.
engineermike
La
2018 GTPP A10
Please explain.
Undisclosed testing method and only one lubrication regime, plus no consideration for a myriad of other critical oil properties.
Basically any liquid with a boundary layer lubrication additive could perform well in his test without indicating how well the oil would serve you in an engine.
