Suspension Questions
5OSONIC
San Francisco, CA
2016 DIB CS
Looking for some suspension suggestions for my mostly daily driven 16' Mustang! Current set up: steeda progressive springs+ steeda pro action (non adjustable) + steeda bump stop.
On my daily commute, I cross over a bridge that has a slight ramp and suddenly flattens out, and every time I drive over that the car gets a bit unstable for a split second. Pretty sketchy. I'm not speeding or doing anything crazy either. It's just a tiny upward slope that flattens out abruptly, but all the other cars I've driven handle this perfectly fine.
I do enjoy taking the car out for a spin on windy roads often, and do a few auto cross events per year just for fun. I just purchased a Whipple SC, so looking for a setup that will reduce wheel hop. I might take the car to the drag strip maybe once a year, but for the most part don't do any hard launches.
In addition to the Steeda components I already mentioned, I also have BMR camber bolts and the Steeda IRS subframe alignment kit (for BMR CB005)
What components should be next? What springs fit my bill better than the steeda progressives? Can I reuse my steeda pro action shocks/struts?
Thanks!!!!
baevid
Houston
2015 Mustang GT
Change out those Steeda bump stops to trimmed stock ones. They’re way too hard for daily driving imo. I had the same setup before.
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Looking for some suspension suggestions for my mostly daily driven 16' Mustang! Looking for a set up that will improve handling/comfort over my steeda progressive springs+ steeda pro action (non adjustable) + steeda bump stop set up. Every time I go over a pot hole my car makes a really loud noise and it feels like the wheel is about to get crushed.
Also, on my daily commute, I cross over a bridge that has a slight ramp and suddenly flattens out, and every time I drive over that the car feels like it's going to fly off and then the car gets a bit unstable for a split second. Pretty sketchy. I'm not speeding or doing anything crazy either. It's just a tiny upward slope that flattens out abruptly, but all the other cars I've driven handle this perfectly fine.
Thanks!!!!
pm your contact info and I will go over your build with you, to meet your objectives,
Thanks,
Steeda Tech
S7N
757
Earth
2022 KIA STINGER GT1 AWD
Yep it’s the Steeda bump stops. I have the same setup and when you go over certain bumps it almost like there is no strut to absorb the impact it’s that hard. Have not got around to changing mine out yet.
5OSONIC
San Francisco, CA
2016 DIB CS
Yikes. So what was the point of paying extra for these bump stops?
@SteedaTech Is it true that I should just swap the steeda ones for the trimmed stock ones to get a better ride?
shogun32
Northern VA
yeah I'm none to happy about that either. I'm replacing with Eibach's fairly soft units cut in half (1.5" long from originally 3"), or perhaps even shorter (3/4"). I have to see how much "free shaft" I have and may even drill the material to give it even more squish. I bought extras for that purpose.
EBS770044 and EBS770060 are the part numbers. Available from Eibach directly (call) or Summit Racing.
https://www.summitracing.com/search...wordMatch&SortOrder=Ascending&keyword=EBS7700
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
John, go for a tide in my car and see if it’s what you’d like more. I’m running steeda ultralite linear springs along with Ford Racing track struts/shocks and their sway bars. No reason you couldn’t run those springs with your current struts/shocks. I’m sure there are other things we can do to make it better. I’m heading towards JRZ coilovers because I’ve maxed out my current suspension needs for road course but I still love my setup and have for the last couple years. Text me if it’s easier since you already have my number.
5OSONIC
San Francisco, CA
2016 DIB CS
Thanks for the help guys. I spent all last night reading like a billion threads and came to the conclusion I will need to switch up my suspension a bit to make it more suitable once the Whipple is installed. The Steeda Progressives I currently have are already a hair too low for my liking, and it would only get worst after the added weight.
Ahhhh, I thought I had narrowed my choices down to SP083s and GT350R springs.... I will definitely look into those ultralites too now haha. I'll send you a text :like:
baevid
Houston
2015 Mustang GT
I'm actually still on the Steeda Progressives with the ProActions non-adjustables and Eibach bumpstops but will eventually move over to the FRPP track suspension and SP083s. The front sits a good 1/2" lower or so than I like due to the Whipple weighing down the front.
In the mean time before upgrading more, just changing out the bumpstops on your current setup will be a world's difference and the cheapest/quickest route to make you enjoy your car again right now.
Bluemustang
2015 Mustang Base GT
Thanks!!!!
Comfort? That's interesting. Is this not pretty much the Steeda "Comfort" package? Lol
Sorry, I have a real hard time not laughing typing "Comfort package". Can't believe they actually called it that.
As far as springs go, it really doesn't get any softer spring wise than those. I believe the front rate goes as low as 145 initially which is even softer than the Base GT springs. As mentioned, I would look into possibly trying some different bumpstops as a first course of action.
Option 2 might be to get a minimum drop linear rate spring to increase your suspension travel slightly and/or possibly looking at getting dampers with better control. Although what you're saying is a bit perplexing as this Steeda setup is marketed as the most comfortable lowered setup. Honestly, I think it's a combination of all 3 - the progressive springs, the bumpstops and the dampers. Sounds like you're lacking control and predictability.
Edit: I stand corrected Steeda's comfort package includes their Active dampers, not the non-adjustables.. My mistake on that.
5OSONIC
San Francisco, CA
2016 DIB CS
Ah, yeah same here. I'm in the same exact boat. The extra weight of the whipple is one of the reasons I'm looking for different springs now. The drop looks amazing, but I scrape every time I go into my garage without the Whipple
Weeeeelllllll, maybe I could've been a bit more clear, sorry about that. The car does drive comfortably for most of the conditions I drive in, but the pothole and bridge impacts are so bad that it sort of makes me forget about the pros of these springs. But as others have mentioned, it sounds like it's due to the steeda bumpstops, not the springs/shock/struts. If I wasn't installing a Whipple on it soon, I would probably just swap out the bump stops and be happy. Hope this clears it up a bit.
Bluemustang
This part is making me think the dampers. But having never used the Steeda bumpstops I have no frame of reference. It may very well be the bumpstops. This car doesn't have a load of travel anyhoo before bumpstop contact.
