Strut Tower Brace missing from your engine bay?
scoobydoonut
Texas Mustang Crazy GIRL
Pipe Creek , Texas
Wendy
2016 Shelby GT350
You do NOT need to remove wipers to put the cowl braces on
PhillMcKraken
DFW Texas
2016 Mustang Ecoboost
The k-brace yes, but the mini extension you do. no way in hell you can get to the three bolts in the rear otherwise, so I skipped it.
Stefan1235
Columbia, MO
2015 Mustang GT
I did it without removing the wipers, just get a 10mm ratcheting flexible head wrench from Home Depot for like $10. I don't have the smallest hands either, so it's totally possible. I just slid my hand back there while using my other hand to pull up on the plastic cover, started the bolts by hand, then used the wrench. It's a pain but it can be done easier than removing the wipers.
PhillMcKraken
DFW Texas
How the hell did you even fit the bolts into it with the cowling still on? I had a hard enough time fitting the bolt on the left that hides under the cowl in there, and that was only half of the way back.
Stefan1235
Columbia, MO
2015 Mustang GT
Ok so I have the part #'a for the Stb, upper K brace, and window brace. Stefan, in your quote you listed a lower K brace:
Lower K-brace and oil pan cover: $100 total shipped (Tasca)
-lower K brace
-oil pan dust cover (fits with lower K brace)
Were these also Ford parts? Or were you referring to the Steeds lower K brace? I noticed you also mentioned oil pan covers...were the oem as well? Ate they different from what comes on a non PP car? If so could you please provide part #'s? Much appreciated.
OEM Ford parts, comes on PP and cars with the 20" wheels, does NOT come on any other GT, here are the part numbers taken from my Tasca order:
FR3Z-5025-A
LOWER C'MEMBER
$35.83
$35.83
FR3Z-6P013-B
INSULATOR
$42.07
$42.07
You need both of those parts, they replace the plastic piece that protects your oil pan.
I was unable to find the bolts necessary to install them through Ford or Tasca. I refered to this post: http://www.mustang6g.com/forums/showthread.php?t=15880, and PM'd Coaster who had a spare set of hardware necessary to install them. You might be able to message him and see where he originally bought his bolts needed to install the lower K brace.
Stefan1235
Columbia, MO
2015 Mustang GT
It actually opens up a little bit once you get back behind the firewall, you just have to pull upwards hard and be confident that you won't break the plastic cowl. It'd definitely be easier with someone to pull the cowl up while you fiddle around with the bolts using two hands.
Ultrakla$$ic
Whoflung Poo
Louisiana
Darren
2016 Mustang GT Ingot Silver Premium
:confused: Why the need for rubber bushings between the brace and chassis?
To protect the paint and level it with the passenger side.
And if you don't have the K-brace, strut tower brace itself makes little sense. Unless it is supposed to be for decoration only, then it makes perfect sense.
I've had STB's on other cars and I'm good like this. I don't road race so I'm comfortable with this setup.
908ssp
Michigan
Alex
2015 GT/PP white
The rubber completely defeats any strength you might get from the strut bar. If you put one on for any reason except for looks DON'T put any rubber under or on top of the strut bar.
Excelerater
Memphis TN
2015 GT
installed mine from CJs,ie Ford Motorsport..both braces and hardware was all included
I did not have to touch the wipers at all and had the whole thing in
installed in 20 mins,pretty simple and straight forward
Alloy
S550 EB
So I just recieved my M-20201-M kit from UPS today. Looks awesome. Ran into a snag however: The box had a few holes in it and guess what was missing? The plastic package was also shredded and thus one of the nuts was missing. Does anyone know the actual part # for this nut so I can order it from my local dealer as I don't want to wait the 10 or so plus days it took to get it here from the dealer I ordered it from.
CTH621
Asia
Mustang 2015 GT, 2022 Shelby GT500
Not sure about the official Ford part # but what I'm sure of is that the nut is an M10 x 1.5 nyloc nut specification. I bought stainless steel nyloc nuts from Ebay as well as an M10 stainless steel washers with 30mm outer diameter. Works the same way as ordering Ford flanged nuts :)
Duttch
Fuquay Varina, NC
2015 Mustang GT (Guard color)
Anybody know the torque specs for the 4 nuts for the tower brace.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Duttch
Fuquay Varina, NC
Found it in Ford Racing manual.
- Install the new strut tower cross brace with new nuts. [FONT=Arial,Arial][FONT=Arial,Arial]Torque[/FONT][/FONT]: 41 lb.ft (55 Nm)
