89Trooper
- Aug 19, 2014
- Central Florida
- Tom
- 2015 Mustang GT
*Click on any picture for a larger image*
Just like with some of the upper braces, unless you ordered a Performance Pack car, the 20" rim option, or a convertible, you do not get the K-Brace that is installed under the car.
Even if you do not want the extra bracing, this installs SO EASILY and afterward you will have the access panel to get to the oil filter! That alone is worth it!
First you'll need to buy some parts. Here is a picture of the two new pieces that you'll have to buy. The metal piece on top is part number FR3Z-5025-A, and the plastic shield is part number FR3Z-6P013-B. The second picture shows how the two parts install as a unit, and the third picture is a comparison to the non-Performance Pack shield at the bottom of the picture.
To remove the old shield (as you would have to do for every oil change), you will have to remove four (4) bolts using a 7mm socket, and two (2) bolts using a 10mm socket. You will need to use the 7mm ones for the new install, but the 10mm ones are not reused. Here is a picture with the shield installed, and another with it removed (you can see where the new brace will install - there is a pink mark next to all of the threaded holes from the factory).
You will also need some additional hardware. I wasn't able to get these from the dealer, so I can't give you part numbers. You'll need six (6) M10-1.5 x 25 bolts. I bought some Class 10.9 flanged steel cap screws. You will also need three (3) additional screws like the ones to remove the original plastic shield. Both are shown here.
Here is a test-fit of the metal brace to make sure that all six of the new bolts thread in easily.
And here it is completely installed. You'll need four (4) of the screws that are in my hand above to attach the new plastic piece to the metal brace, two (2) are re-installed in the front of the new panel, and one (1) is needed to keep the access door closed. IMPORTANT: don't tighten anything until every bolt is started, and until you make sure the hole for the access door lines up where it needs to be. Torque for the six (6) bolts is 42 ft-lbs, just like for the strut tower brace in the engine compartment.
Here are some pics of the access door open and closed. How nice it will be to change my oil next time!
